Old 02-28-2008, 05:44 PM   #151 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Shultz - I think that pic is representative, not actual.
It'll be interesting to find out what body style the Tercel is. It could be a coupe, wagon (I think), or 2- or 4-door hatchback.
Old 02-28-2008, 05:46 PM   #152 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Yes, I was thinking the same thing. I e-mailed the seller asking what body style it is.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 02-28-2008, 09:21 PM   #153 (permalink)
bennelson's Avatar
S10 - '95 S10
I just got a reply from the guy selling the Tercel.
He said he didn't have a photo of it, but it looks like this. And then had a link to that exact same photo posted above!!!
Anywhoo - it's a two door. Looks like a trunk, not a hatch, in that photo, right?
I would prefer a hatch, but trunk would work too.
Hoping to actually go look at this one. Cross my fingers that the body isn't too bad.
My YouTube Videos
Old 02-28-2008, 10:38 PM   #154 (permalink)
Hatch is more practical, but the trunk is safer (no batteries in the passenger compartment).
One thing I would do is bring along a ratchet set. The guy is saying it won't start because of the starter. But just make sure the engine isn't seized - put a ratchet on the crankshaft pulley and see if you can turn it fairly easily. If you find it's seized, you'll have a much better bargaining position
Old 02-29-2008, 12:03 AM   #155 (permalink)
bennelson's Avatar
S10 - '95 S10
Another Craigslisting!
"96 Geo Metro Hatchback 2-Dr black w/pink pin striping. Has two minor dents but no rust. 140,000 miles 3cyl 1 liter motor. Runs good, but 5 speed transmission needs to be replaced/rebuilt due to worn syncronizers."
Somebody please tell me that worn syncronizers are not a big deal and I can fix them!!!!
A 96 also means it should work with a Scan Gauge and have an airbag!
My YouTube Videos
Old 02-29-2008, 12:05 AM   #156 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
You can fix the synchros easily (get a new transmission!)...you can actually fix them, but in this case another tranny would likely be cheaper and easier.
Old 02-29-2008, 12:14 AM   #157 (permalink)
I note you didn't post the link to that ad. Must mean you really want this one
Go for it! It's the nicer body style, though 150-200 lbs heavier than the ForkenSwift shell.
Synchros... it's more of an issue if you go for a clutchless connection, because you rely entirely on the synchros to permit you to shift.
That said, I'd also bet money that this car has the wrong weight (too heavy) of oil in the transaxle, and going to a lighter oil will help some.
Also, if you do a 72v conversion, you can just leave it in 2nd gear for the vast majority of your driving. 48v/225A isn't powerful enough to get away with that.
Another plus, the last gen Metros had ridic ground clearance. If you stick 600 lbs of batteries in them, it won't be scraping the pavement like some other small cars will.
Old 02-29-2008, 12:17 AM   #158 (permalink)
If the motor runs well & has decent compression, you can probably swap it with someone for a tranny with decent synchros on teamswift.net.
Old 02-29-2008, 12:42 AM   #159 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
if the toyota is in good shape you SHOULD be able to start it by poping the clutch, make sure the battery is good (lights come on?) and if it has a carburator pump the gas a few times and maybe once more for good luck as it hasn't run in a while, then just push it down the street, a nice walking speed is ideal, pop it in to 1st or 2nd gear and pop the clutch, you could even drive it like that for a while, of course you should do this AFTER you get the guy to lower his price.
Old 02-29-2008, 12:58 AM   #160 (permalink)
bennelson's Avatar
S10 - '95 S10
Does is sound like that Geo could be driven (just enough to limp back to my house) with the stated transmission problem?
Towing is one more expense/complication.
I figure that for a small front wheel drive car, I could use one of those "car tow-ers" from the moving rental place, but I haven't gotten around to welding a ball hitch on the back of the pickup truck yet!
My YouTube Videos
electric car, electro metro, geo, metro
Daox's 1997 Paseo Build Thread Daox EcoModding Central 239 11-24-2011 09:44 AM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 05:31 AM
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 33 10-02-2008 11:22 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 01:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 02:23 PM
