Old 06-26-2008, 07:10 PM   #321 (permalink)
ttoyoda's Avatar
Man, I sort of wish I would have gone to a shop too. He does really nice work. I bet your car will actually work!
Your car is going to work fine. And for your next car, you will have an excuse to buy a metal lathe. Once you have one, you will always wonder how you got along without it.
Old 06-27-2008, 10:18 AM   #322 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Originally Posted by bennelson View Post
He cut an access panel into the bottom of the transmission houseing so that we can get a hand in there to make the spider and everything line up. Then it will have a little custom cover to keep anything else from getting in there.
We did the same thing on the ForkenSwift's bell housing. Not big enough to get a hand in (a smart idea) but big enough to shine a light in to at least inspect the coupler should we need to (haven't needed to).
Old 06-27-2008, 11:36 AM   #323 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
I would have cut a hole in the bell housing, but there was already one there, where the starter motor was attached! Those Germans thought of everything.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
Old 06-29-2008, 09:36 PM   #324 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Past breaking even on car!
I just sold the gas tank and radiator from the Geo Metro. The parts are all going to a another black Metro. Hey, the more of these we can keep on the road, the better!
After selling all the various parts, I have just came out a little ahead on the cost of the Metro.
Yea!!!!
I still have some money in the forklift, mostly because of the cost of transporting it.
Anyhoo! Free car frame to convert to electric!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 06-30-2008, 10:40 PM   #325 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
No, that's not my Geo Metro - rather, it is the Chevy Metro I sold the gas tank and radiator to.
Notice it has a different grill and headlights.
The guy said he doesn't like those headlights and would really rather have the sealed beam headlights like I have.
I kinda like the grill on his car. That car is a 4-cyclinder automatic transmission, with air conditioning. The engine looked HUGE compared to mine.
I also thought his hubcaps and semi-silver window tint looked really nice.
My YouTube Videos
Old 07-17-2008, 08:48 PM   #326 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
Adapter Plate Ready!
I got a call tonight from the machinist. He has the adapter plate cut out.
I went over there and got to see it. He has the Lovejoy welded to the clutch hub and the plate was loosely screwed to the tranny bell housing.
He cut an access hole in the bottom of the housing so that we can get a hand in there to line up the couplers.
I took the motor end cap home with me (in a backpack, on the electric cycle). I think that end cap weighs as much as the entire motor for the cycle!!!!
Now I have to put the motor mostly back together so I can see what distance is needed between the transmission and motor. The two will need spaces to make up whatever space that is.
My YouTube Videos
Old 07-17-2008, 10:20 PM   #327 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I moved your metro update post to the metro thread for you. This is just a bump for the thread.
Old 07-17-2008, 10:51 PM   #328 (permalink)
Cool - glad to see an update. Looking forward to seeing the e-motorcycle this weekend, too.
Old 07-18-2008, 07:10 AM   #329 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Yeah Ben! Keep this thread rollin.
Old 07-18-2008, 12:03 PM   #330 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
Anyone have suggestions about bearings?
I figure that while the motor is apart, I might want to replace the bearings.
Doesn't really look like there is anything wrong with them, but the commutator doesn't look in great shape, and I figure the bearings haven't been changed since the commutator was new. On the other hand, are bearings in electric motors designed to last forever?
The only moving parts in the motor (literally!) are the two bearings on either end of the rotating shaft, that's it!
I figure that since the motor is apart anyways, now is the time for new bearings if I am going to do them.
Is anyone familiar with turning a commutator on a lathe? I guess this is what people used to do with starter motors to fix them. Put the motor shaft in a lathe, and turn down just a tiny bit off the commutator, so it is shiny and smooth. Nice, new, clean surface for the brushes to rub against.
Anyone done this before?
My YouTube Videos
electric car, electro metro, geo, metro
Daox's 1997 Paseo Build Thread Daox EcoModding Central 239 11-24-2011 08:44 AM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 04:31 AM
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 33 10-02-2008 10:22 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 01:23 PM
