Old 02-05-2008, 07:27 PM   #51 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
That guy is asking $1200 for the Miata.
I guess right now I am really leaning towards the simpler/lighter/cheaper the better.
Miata might make a better second EV conversion for me.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 02-05-2008, 07:32 PM   #52 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
Kelly 24v - 84v controller
Originally Posted by bennelson View Post
You are right on with 72 volts.
Controller costs seem to jump up above 48 and above 72 volts.
72 volts seems like a reasonable way to go.
There is a Kelly controller that is quite a bit cheaper than alltrax and Curtis (and Zilla, and etc...) that goes up to 84 volts. Their 72v 400amp controller is $389 NEW from their site. I didn't find the 84 volt one there today, which I have been eyeing, but they said they still carry it.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
Old 02-05-2008, 08:53 PM   #53 (permalink)
PaulH
PS: Darin is stalking me on other forums
Then quit doing such dang awesome cheap EV conversions using a forklift! You know he won't be able to resist reading about such a project.
Old 02-05-2008, 09:05 PM   #54 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Just curious as I've only browsed through a few things on EVs. How hard/expensive is it to find a controller with regenerative braking capabilities?
Old 02-05-2008, 09:23 PM   #55 (permalink)
PaulH
Here is a Kelly Controller price list:
KD72201,200A,PM with Regen Kelly $ 319,
KD72301,300A,PM with Regen Kelly $ 369,
KD72401,400A,PM with Regen Kelly $ 439,
KD72501,500A,PM with Regen Kelly $ 519,
KD72601,600A,PM with Regen Kelly $ 599,
Each of the controllers are programmable from 24v to 72v.
I don't think regenerative braking works very well with DC series wound motors, but I don't have any first hand info on that.
Old 02-05-2008, 10:12 PM   #56 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
From what I have heard, nobody has much experience yet with the Kelly controllers. They do look to be reasonably priced AND offer regen.
Series Wound DC motors aren't ideal for use as a generator. Some of the other styles of motors work well though.
Mr. Sharkey's Electric Rabbit uses a shunt-wound motor and features regenerative breaking.
I have heard that permanent magnet DC motors also work well for generation.
Regenerative braking is NOT high on my list of priorities. As this will be my first electric car conversion, I am looking for cheap/easy/uncomplicated.
Now if I can end up easily adding regen brakes, I definately would.
My YouTube Videos
Old 02-05-2008, 10:19 PM   #57 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Here's a conversion using a 72v Kelly:
http://galaxy22.dyndns.org/ev-talon/
Old 02-06-2008, 10:27 AM   #58 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
Snowbound!
Feb 6th.
It's the middle of a blizzard here. My wife is home from work because of it. Also she has the sniffles & cough.
I am going to try to remove the wheel drive motor from the forklift today.
We'll see how long it takes my hands to go numb.
My YouTube Videos
Old 02-06-2008, 01:14 PM   #59 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
I wasn't able to figure out how to get the drive motor off.
First, I had to disconnect a weird drum brake to get at anything else. Then I removed all the bolts that looked like they were holding the motor on. I put a nut on the end of the drive shaft and carefully tapped on it a little. Not sure what else is holding it in place other than a gasket connecting it to the block it is attached to.
After all that, I decided to remove the big pump motor. It wasn't nearly so difficult, bolt one bolt was nearly inaccessable. It took about half an hour of turning the bolt a tiny bit, sliding the wrench off, flipping it over, wrench a little more, flip it over, repeat....
The big pump motor weighs around 120 lbs, as best I can tell, I had to balance it funny on the scale to weigh it.
The outside measurements are 9" diameter and 12" length
Still, this one doesn't have a real drive shaft either.
My YouTube Videos
Old 02-06-2008, 01:27 PM   #60 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
$$$$$ - Motor!
I just talked on the phone to a guy in the Raymond (fork lift brand) parts department.
The motor has an ID plate on it, so I just gave him the part number and asked what it would cost for a new one.
Guess how much?
$2283.95!
My YouTube Videos
electric car, electro metro, geo, metro
Daox's 1997 Paseo Build Thread Daox EcoModding Central 239 11-24-2011 08:44 AM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 04:31 AM
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 33 10-02-2008 10:22 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 01:23 PM
