Old 11-18-2008, 12:16 AM   #671 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
90 day: 25.35 mpg (US)
Electric Heat
Sounds like a neat way to keep warm! Hey, if we're all using electricity from our Solar/Wind installations that we're going to have in the future then it will be perfectly okay to use it that way, huh!
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 11-18-2008, 12:32 AM   #672 (permalink)
Fossil-Fuel Optional
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 26.95 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Even if I used enough electricity heating the car to bring to total car energy use down to as inefficient as a gasoline car, all my electricity is STILL from renewable sources.
You CAN make electricity out of thin air - wind, solar, etc. You can't do that with gasoline!
Still, we shouldn't be wasteful with the stuff. I am trying to heat the car as much for safety (no frosted windshield!) and efficiency (warmer batteries run better!) as I am for comfort.
If I was only trying to keep warm, I would just stick with the great down coat I got last winter!
Old 11-18-2008, 08:08 PM   #673 (permalink)
40 mph - Someday
TomEV's Avatar
Citicar - '76 Citicar
90 day: 151.7 mpg (US)
I modified a cheapie *mart heater (resistive coil + fan) for the Citicar. It worked OK from the traction pack, but I only used it once or twice as a heater. It tended to kill my wh/mile. (used about 10% more power) With only six batteries, it makes a difference...
I modified it (again!) and it is now in service as a defroster. It only needs to be on for a minute or two, and works much better than paper towels
Old 11-18-2008, 08:46 PM   #674 (permalink)
bennelson's Avatar
S10 - '95 S10
My plan was to use some sort of a basic, 12V heater/blower to defrost the windshield.
Definately colder in Wisconsin than California!
I think a combination of pre-heating from the wall outlet, and occasional on/off of a cheap-o electric heater should work fine.
Let you know more as it gets colder!
Old 11-18-2008, 09:45 PM   #675 (permalink)
bennelson's Avatar
S10 - '95 S10
Disaster!!!
I think I broke my Geo Metro's coupler!!!
Was driving to the grocery store, heard mechanical noise - POP - motor didn't spin the transmission any more.
Cold and dark out. Won't know for sure until morning. Good thing I have that towing setup installed.....
Old 11-18-2008, 09:54 PM   #676 (permalink)
Wannabe greenie
The Clunker - '90 Accord EX sedan
90 day: 36.4 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 37.11 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Yipes. Hopefully the motor didn't overspeed.
Old 11-18-2008, 10:25 PM   #677 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
You kids and your hopped up 72v electric cars. Always breaking things with all that POWER! Sheesh.
Just a word of warning about towing the car: if you leave it in neutral, bungee the shift lever so there is absolutely NO way it can accidentally get into gear. As dubious as this sounds, I have heard of two motors destroyed by towing. And both owners claimed they left the shifter in N when they started the trip. You could pre-emptively put it in 5th gear, but then you're wearing the brushes/comm out for no reason.
When we towed the ForkenSwift to Ottawa, I put a bungee on the shift lever to hold it in N. Paranoid after those stories!
Old 11-18-2008, 10:30 PM   #678 (permalink)
Shadetree Engineer
Tango Charlie's Avatar
Olivia - '03 Vibe
90 day: 37.26 mpg (US)
Ah, that sucks eggs.
Darn that 666 curse...
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 11-19-2008, 01:14 PM   #679 (permalink)
bennelson's Avatar
S10 - '95 S10
Yep, the 72 Volts of Fury was obviously too much for it...
On the upside, I just got the e-mail that my Curtis PB-6 potentiometer box is in the mail!
Old 11-19-2008, 02:57 PM   #680 (permalink)
bennelson's Avatar
S10 - '95 S10
Yep - It's the coupler...
I picked up the car with the S10 and tow bar.
I am getting better at hitching it up that way now.
Once I had the car home, I jacked it up and took a look through the coupler access port on the bottom of the transmission.
It looks like the two halves of the lovejoy coupler have been constantly wearing against each other, ever since installation. I also think the rubber spider was never in there quite right. I installed the motor to the transmission from under the car, by myself, struggling with it the whole way.
The transmission half of the coupler also was forced back to the sleeve covering of the transmission shaft. I think that is superficial damage, but won't know until I take everything apart.
When I fix and re-install this, I am planning on doing the combined motor and transmission, attached to each other, and install them into the car from below.
In this way, the alignment of the motor to the transmission can be checked and made perfect - BEFORE - I put it in the car.
See more photos here:
MobileMe Gallery
electric car, electro metro, geo, metro
Daox's 1997 Paseo Build Thread Daox EcoModding Central 158 11-17-2009 10:03 PM
Metro taller tranny swap thread: +5% efficiency gain MetroMPG EcoModding Central 33 10-02-2008 11:22 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 01:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 02:23 PM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 25 04-01-2008 08:13 AM
car hire cape town
Car hire is the best way in which to explore the beautiful city of Cape Town and the surrounding region.
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
