Old 11-19-2008, 08:40 PM   #681 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Video Update 11/19/2008
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 11-20-2008, 01:16 PM   #682 (permalink)
You don't happen to have the exact specs on the lovejoy couplings and spyder do you?
I am almost finished with my EV, but I stayed away from the lovejoy couplings because they couldn't handle the torque. At least the ones that fit my motor shaft couldn't handle it, so I had to design one and have it machined up.
The lovejoy connections seem to be measures in inch-lbs for torqure, so you should make sure that your coupling has a least 3500 inch-lbs for the least chance of things going wrong.
Now get that fixed so we can see more pics of the EV driving and not being towed!
1996 Civic LX EV
Old 11-20-2008, 06:28 PM   #683 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
That's quite the coupler picture, Ben. I was going to waggle my finger and give you the hairy eyeball for not occasionally peering through the inspection window you purposely cut into the bell housing just so you could keep an eye on things!
But then I remembered I haven't looked through ours for quite ... some ... time.
But I will now!
In fact, e-mailing Ivan to show him what happened.
Hope it's not too hard - or spendy - to repair.
Old 11-20-2008, 11:35 PM   #684 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
Anyone just replace, or is about to replace the clutch on their Metro?
I could use your old clutchplate! I really only need the splined bit out of the middle for use in making a new coupler.
I really don't know for sure if I need a new transmission shaft splined bit or not, until I get the car apart, but even if I don't, it wouldn't hurt to have a spare!!!
My YouTube Videos
Old 11-22-2008, 12:37 AM   #685 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
I don't have one handy, but I think Coyote might.
I am going to the boneyard tomorrow (Today?) and will loook for an engine that has been left on the side of the road for spare parts.
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 11-23-2008, 12:39 PM   #686 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
I just pulled the motor out of the car.
The coupler is totally worn out. The spines on the motor shaft and motor half of the coupler both look good.
I can't get the transmission half of the coupler off the tranny shaft.
I am trying to pull the transmission next. That's a huge pain in the butt!!!!!!
My YouTube Videos
Old 11-23-2008, 01:43 PM   #687 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
Could you use an abrasive cut off wheel in a Dremel tool to cut it off?
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 11-23-2008, 02:15 PM   #688 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
Yea! Got the transmission out!
Once it was out, I was able to get the coupler half off. It look lots of wiggling and prying, but it came off!
My YouTube Videos
Old 11-23-2008, 05:01 PM   #689 (permalink)
Glad to read you're attacking the repair, Ben.
Old 11-23-2008, 05:18 PM   #690 (permalink)
"Crush"
bennelson's Avatar
S10 - '95 S10
Both halves of the coupler will need to be rebuilt.
The splines on both the motor and the transmission shaft both look good, but the splines on the tranny shaft coupler half are GONE! This is from the center of an old clutch plate, machined down.
That means I need to find a new donor clutch plate to make the new transmission half of the coupler!
My YouTube Videos
electric car, electro metro, geo, metro
Daox's 1997 Paseo Build Thread Daox EcoModding Central 239 11-24-2011 08:44 AM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 04:31 AM
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 33 10-02-2008 10:22 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 01:23 PM
