Old 01-19-2009, 11:10 PM   #921 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
It looks like a television designed by Dr. Suess!
I ran the car through the carwash today. I couldn't resist shooting video, but I only had my digital still camera with (which has a motion record feature!)
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-20-2009, 07:58 AM   #922 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I take it you went through with the bellypan installed?
Old 01-20-2009, 11:01 AM   #923 (permalink)
bennelson's Avatar
S10 - '95 S10
Nope! Pulled off the bellypan to work on the motor mount - haven't put it back in yet.
I unplugged the charger this morning and then let the batteries sit for a while.
I measured the voltage of each battery.
These are the voltages of the charged, rested, non-heated batteries - temperature is 15℉ outside. Batteries 1-4 are in the truck/hatch, and batteries 5-6 are under the hood, where the radiator used to be.
I then drove 3.9 miles, and measured the voltage again.
Here is the battery number, then the voltage while charged and rested, then the voltage right after the 4 mile ride. The third column is what the voltage was about an hour and a half later.
1 12.93 V 12.48 V 12.68 V
2 12.86 V 12.38 V 12.60 V
3 12.74 V 12.19 V 12.43 V
4 12.77 V 12.18 V 12.45 V
5 12.89 V 12.32 V 12.64 V
6 13.01 V 12.51 V 12.78 V
Note that the voltages I listed are when the car isn't moving. (The batteries are NOT under load!) The batteries drop in voltage real fast while driving, especially accelerating or going uphill.
Looks like batteries 3 and 4 aren't doing as well. Maybe I need to individually charge these two after my next charge cycle.
My YouTube Videos
Old 01-20-2009, 05:10 PM   #924 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Originally Posted by bennelson View Post
Later, I will add the voltage of the batteries after they have sat for an hour or so.
Might it also be useful to check voltages after a longer rest period - say 15-24 hrs???
Old 01-20-2009, 05:21 PM   #925 (permalink)
bennelson's Avatar
S10 - '95 S10
Do you mean to say to check them 24 hours after being fully charged and the charger turned off or drive the car, park it, and check the voltage 24 hours after that?
I don't want my batteries sitting around discharged for too long, but I suppose 24 hours once won't hurt them.
My YouTube Videos
Old 01-20-2009, 06:37 PM   #926 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
From what I'm hearing, a couple of hours of waiting is okay for checking voltage after a charge.
Also, shouldn't those be at something like 13.2 volts charged??? Maybe you're not getting them fully charged???
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 01-20-2009, 06:55 PM   #927 (permalink)
bennelson's Avatar
S10 - '95 S10
The charger I am using is a "gentle charger".
These are gel-cell batteries. The insides of them are something like Jello. They need be be charged at a lower voltage than other battery types.
Flooded lead-acid batteries can be charged at a high voltage. They will just convert some of the water/acid into hydrogen and blow it off. You then have to replace it with some distilled water.
The gel-cells are sealed. If you charge them at a high voltage, they can get voids in the Jello and wreck them.
The big advantage to these batteries are that I don't have to worry about them leaking, tipping over, spewing hydrogen gas, etc.
Modern SLAs & AGM batteries have all those same advantages while worrying a lot less about charging voltage. Gel-cells aren't used much any more. In fact, I got such a good deal on them because they were being replaced by AGM batteries in their application.
So, yeah, my batteries are always going to read a little lower because of their style and how they are charged.
My YouTube Videos
Old 01-20-2009, 07:06 PM   #928 (permalink)
Intrigued's Avatar
Doh!
Oh, yeah, I remember Gel-cells... now that you mention them...
Old 01-20-2009, 07:22 PM   #929 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Maybe a full cycle will help the batteries stabilize a bit? I mean drain them until they won't drain anymore, and then use a trickle charger to bring them back up to full voltage... might take quite awhile, but if you think it's worth it to try, it's worked for all my dad's car batteries.
*He's been using the same 1000 Amp (850CCA) battery in all his cars for about 15 years now... that ^^^ is how he keeps it fresh... once a year. It's a lead acid battery though.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 01-21-2009, 07:30 PM   #930 (permalink)
bennelson's Avatar
S10 - '95 S10
Emissions sticker
I finally got my emissions sticker in the mail today!
All I have to do is stick that on my rear license plate and it is officially a 100% street legal electric car!
My YouTube Videos
electric car, electro metro, geo, metro
Daox's 1997 Paseo Build Thread Daox EcoModding Central 239 11-24-2011 09:44 AM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 05:31 AM
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 33 10-02-2008 11:22 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 01:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 02:23 PM
