03-31-2009, 08:14 PM
#11 (permalink)
MR2 - '93 MR2 Turbo 90 day: 22.92 mpg (US)
Originally Posted by TestDrive
For most cars, you're better off getting two 36" x 48" pieces for each section, one for the left side, one for the right. My car is fairly small, and 48" wide still isn't close enough to cover.
Originally Posted by Shawn D.
No, " Coroplast" is a brand name. The sheet you are talking about is not corrugated, but is instead extruded cells. Corrugations are undulating waves/patterns in a single-thickness material, which is often bonded to other materials (i.e. cardboard). It's not the cells that make the cardboard or plastic corrugated, but the manner of making the cells.
But, Coroplast claims they're "The Leading Manufacturer of Corrugated Plastic":
www.coroplast.com
04-01-2009, 07:48 AM
#12 (permalink)
Harebrained Idea Skeptic
www.coroplast.com
They're using that term generically to describe it to folks who don't understand what "corrugated" means.
04-15-2009, 07:05 AM
#13 (permalink)
econ00b
If they dont understand what corrugated means.... how would the term "corrugated plastic" help exactly?
04-15-2009, 12:20 PM
#14 (permalink)
Even without precise knowledge, people in a hurry can gain useful information from analogies.
04-15-2009, 12:43 PM
#15 (permalink)
Right on Bob!
American by right
Ecomodder by choice
Hypermiler by necessity
04-15-2009, 12:58 PM
#16 (permalink)
Of course, now we have to use "washboard" where "corrugated" is more accurate, and it takes whole sentences to define the difference between coroplast and cardboard. I used to use "Polypropylene, extruded to resemble corrugated cardboard" but the short form has gotten shorter, and the correct form, longer. Perhaps "fluted" will gain currency.
04-15-2009, 01:20 PM
#17 (permalink)
PSmodder lurker
Find your local plastics distributors and ask for lexan thermoclear, Thermoclear, Verolite, Twinwall or polygal structured polycarbonate sheets. They are typical thermoglazing glazing sheets for lightweight, high impact resistant & formable sheets. They are usually 48"x 96" and could be ordered up to 72"x 144" so you could under-cover in one sheet! They are clear, opal white or solar bronze. No problem with clean steel/carbide-tipped blades. Go slow and it doesn't melt. Minimal tools? Easiest, score & snap break. If anyone is able-$ and technically inclined, precise laser/water cutting is best.
04-16-2009, 04:53 PM
#18 (permalink)
Another nice option-"alumacore". You guessed it, a coorugate material made like cardboard, but very stiff and very light. Not inexpensive or flexible but very durable. Sign shops stock it.
