Old 10-10-2008, 10:44 PM   #11 (permalink)
Princess - '08 HHR LSSR
90 day: 23.66 mpg (US)
The tires have helped
The tires (or lowering?) have helped. I was looking back over my notes and testing and it defnatly has helped. For instance I have went from 29.4 MPG @ 70 to 32.25 @ 70 MPH and if you add in the 10% speedometer error then it is 35.47 MPG. Note my GPS is only showing about 5% error? and all the tire web sites says there is a 10% difference with those tires?
That is with the air conditioner on high (it is Texas!) and I try to do the same 150 mile test run and test mileage at several speeds both directions. I try as much as possible to eliminate me as a variable. I record weather, altitude, wind, put it on cruise at the testing speed then clear the DIC and make a 20 or 25 mile test run.
Went from 37 @ 60 to 38.4 MPG and if you add in 10% speedometer error it is 42.24. RPM has been lowered 100 to 250 RPM at highway speeds.
One of the reasons I tested at speeds up to 85 MPH is because I do not feel the lowering and front spoiler will make much difference at low speeds such as 40.
I have not done any real testing with the front spoiler yet and not sure if gains will even show but I do not think it will hurt anything.
I think aero dynamic mods will help more at higher speeds and horse power like underdrive pulleys and removing wieght will help more at the lower speeds. Actually I think (hope) the underdrive pulleys will help at all speeds.
Once I get the mechanical mods where I want them then I will try to learn more how to drive effeciently. I know speeds over 60 or 65 is not effecient but it was needed for my testing.
My goals may be a little different than many here. I want to get the best mileage possible with out giving up my creature comforts. It is often over
100* here and I am not going with out my air conditioner. I drive a car to get to where I need to be so I want to tune my car to get the most out of it at the speeds I drive 60-70.
I am trying to build a car that gets good mileage, looks good, comfortable and is fun to drive. So what I consider "good mileage" may not be very impressive to many of you. Curly
Old 01-22-2009, 12:03 AM   #12 (permalink)
Latest results
The car is coming along nicely, mileage is getting better the car looks good in my opinion.
Soon I will do the Trifecta Tune and I think it will bring everything together for good performance and mileage.
Lately mileage has been down some I think due to Winter blend fuel and colder weather. My city mileage had been up to 26 and it is down around 21 now...... Should be (hopefully) a temporary thing.
I do not think the Apexi fuel controller works with the Chevrolet cars. That does appear to be an interesting addition though to fine tune the fuel ratio.
The Ecotoc only has the air conditioner and alternator running off of the crank so I do not think an underdrive pulley would help this car much if any.
Old 01-22-2009, 01:33 AM   #13 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Underdrive pulleys don't help much.. they're usually the first thing that ricers get for their cars thinking that they're going to get some magical horsepower increase from them, and they don't. To further aid the propaganda marketing that those companies use, the ricers don't SAY that they didn't get much or any gain.
On top of that, most times, the underdrive pulleys aren't tested for road use, will fail visual emissions checks (for some reason, or maybe not anymore) and aren't properly balanced, meaning they'll chew up your motor and spit it out, for a potential 1% increase in engine efficiency.
It's really not worth it. Spend the $100 on something that will actually get you somewhere.
I do believe the Apex'i SAFC is universal. The VAFC is not. It's designed to control fuel/ignition curves for Honda cars when in Vtec, also a worthless "tuning tool".
The SAFC can also be used as a ScanGauge, of sorts. Given that you're running OBD-2, you're more likely to be happy with a piggy-back system instead of standalone tuning. The problem with standalone ECU tuning is that it kills the "learn" curve of the ECU. The ECU can no longer be used in "learn" mode, as it will rewrite the tune based on core parameters, and revert to OEM specs over time. Also, if you disconnect the battery, or it goes dead, your tune is gone, b/c the ECU will lose it's "learned" information and revert back to core values.
I'm not sure about emissions laws in TX, but I know that if you're going to run a CAI, you should get a reputable one. They don't all do the same thing, regardless of what anyone tells you. A dyno sheet with a standard short ram intake and a full CAI shows the same HP increase across the board, except the CAI shows a spike at a given RPM range. That RPM range can be tuned by the manufacturer to give a spike at lower or higher RPMs.
AEM makes one of the best intakes there is, IMO (and in the opinion of several thousand street tuners, apparently). If you don't want to pay for an AEM intake, ICEMAN is the next in the line. They use a light, thermo-plastic resin that actually insulates the intake from engine bay heat soak.
K&N and other oil-soaked filters have been known to cause damage to your sensors, so probably best to stay away from them. It's already been discussed 1000's of times here and elsewhere that your air filter isn't a problem anyway, under normal driving situations.
Basically, you'll want to do anything you can to make more power with the fuel you're already using, if you're looking for more power and better mileage.
CFG83 - 215/55R16's on 16x7 wheels will fit under your car, even lowered slightly.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 01-22-2009, 03:01 AM   #14 (permalink)
Mechanical is a taller top gear. Also a hotter thermostat. Some cars have 170 degree thermostat. Some engines like to run a little hotter and produce better numbers. As far as the Intake the stock one will be better for fuel economy. Reading from your posts you're more inclined towards performance than fuel economy so you might not get rid of that intake. My stock intake setup gave me 38-39mpg on the freeway. When I put an Injen intake my freeway number went down to 31mpg. So it might be hurting you more than you think.
What else...the apexi safc/vafc requires some dyno time and might not get you the results you want. I would advice getting a scanguage 2. You'll raise a couple mpg from that alone. I have been told people that have standalone ecu's only raise their mpg by 3. Might as well get yourself a scangauge 2 and put out the same if not better numbers and it's plug and play.
Old 01-22-2009, 01:31 PM   #15 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
It seems like the rear wing would be hindering the airflow at the rear, since it appears to be slightly above the roofline. If you can cleanly take it off, it might be something to try.
Winter daily driver, parked most days right now
Summer daily driver
Old 01-22-2009, 04:16 PM   #16 (permalink)
Particularly for the winter, get rid of the CAI! You might even look into a WAI, taking warm air from somewhere hot in the engine bay like around the exhaust manifold. Less power, true, but you'll be reducing the pumping losses resulting from pulling air past a nearly-closed throttle plate at cruise.
Pump those tires up to the max number found on the sidewall. Lower rolling resistance is good!
Try ditching the wing. There's a good chance that will help.
Consider a belly pan.
Consider wheel skirts.
Consider a grille block, particularly with the cold winter weather. (OK, let me put that "cold" in quotation marks, as you folks in TX don't get much colder than we do in CA... )
Do get a ScanGauge. That can let you make small changes to your driving which can improve your fuel conomy more than any mechanical mod you can hope to make.
-soD
Old 01-22-2009, 07:09 PM   #17 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
As your vehicle has relatively tight wheel wells, flat wheel covers (Mooneyes) may be as effective as skirts and easier to live with.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 01-22-2009, 08:14 PM   #18 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I think I too suggested this in your other thread. ( was that you ? )
I can understand not wanting to mess up the looks of your vehicle.
If you put on some plain wheels with moon wheels and then stored the 'nice' ones in the garage, it would only take you 15 minutes or so to put the 'nice ' ones back on.
Here is what your HHR would look like with moon wheels :
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 01-22-2009, 09:57 PM   #19 (permalink)
Try some side skirts to match your front air dam. Won't mess with the looks at all...might match well.
On taller tires if you go skinnier while going slightly taller you are usually better off. Go too tall and you definitely lose. You basically do not want to increase the weight of the tire at all or the width (or the rolling resistance).
Old 01-25-2009, 02:09 PM   #20 (permalink)
Don't inflate to max sidewall pressure like someone said. That will reduce the life of the tires by causing uneven wear.
could we estimate the gains expected from mods modmonster EcoModding Central 9 01-15-2010 09:32 PM
GM mods the Sierra hybrid pickup: aerodynamic tweaks + LRR MetroMPG EcoModding Central 4 12-27-2009 12:11 PM
Ford Ranger Mods So Far... landscaper52 Aerodynamics 18 09-16-2008 06:14 PM
Aero mods for our coupes?? swoody Aerodynamics 14 09-05-2008 03:07 AM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 08:46 AM
