Old 08-09-2011, 08:26 PM   #1 (permalink)
Best Programmable Fuel Injection ECU for Two Cylinder engine
Do any of you know of any good programmable fuel injector kits that will run a two cylinder motorcycle engine? I'm hoping for the ability to fully customize settings, but also has the ability to sense and adjust to changes in atmospheric pressure and elevation changes. Also possibly mass air flow. A DIY kit is preferred but I'm willing to buy off the shelf if its reasonable.
Thanks,
GoGogebic
http://gogebicxp.blogspot.com/
Old 08-09-2011, 08:50 PM   #2 (permalink)
Red Car - '96 Cougar XR7
90 day: 25.99 mpg (US)
Look up megasquirt. It is a sweet DIY system that you can build or buy partially assembled. There is a lot of information to take in so make sure you have plenty of time. I would have posted a link, but since I have less than 5 posts I am not allowed.
Old 08-10-2011, 02:47 AM   #3 (permalink)
Blow stuff up
phunky.buddha's Avatar
S2000 - '03 S2000
90 day: 24.42 mpg (US)
I was going to chime in on Megasquirt as soon as I saw the thread title too.
MegaSquirt - Electronic Fuel Injection Computer by Bowling and Grippo ©2010
DIYAutoTune.com Megasquirt Kits / Assembled Engine Management Systems, Wideband o2 Sensor Systems and tuning products
Intercrew Auto Salon
Old 08-10-2011, 12:50 PM   #4 (permalink)
theres also: MicroSquirt® by Bowling & Grippo ©2005
Pre-assembled, looks small too
Old 08-10-2011, 01:23 PM   #5 (permalink)
MS1 with MSextra firmware is your cheapest option. Microsquirt is smaller and more appropriate for applications where space is limited.
Megasquirt Product Comparison
Megasquirt works by reading manifold pressure through a MAP sensor so atmospheric pressure is irrelevant. You can add a second MAP sensor to compensate for altitude effect on back pressure.
Let me know if you have any specific questions. I built and installed 3 so far.
Old 08-11-2011, 02:39 PM   #6 (permalink)
ncs
RockMagnet - '04 Impreza wagon WRX
90 day: 26.16 mpg (US)
MegaSquirt 3 now supports MAF based fueling, which is more accurate/effecient than the MAP based speed density setup.
MegaSquirt-3 Features
Old 08-11-2011, 10:47 PM   #7 (permalink)
But why would you want to?
