Old 03-30-2012, 11:05 AM   #31 (permalink)
I am of the opinion that there are no "miracle" spark plugs or spark plug wires. As far as plugs are concerned, if you have a stock engine, as others have said, stick with the OEM recommendation.
As far as wires are concerned, The OEM considers them a replaceable item, and they only last so long. If you don't have misfires, they are probably OK. If you do, and new plugs don't cure it, replace the set with an OEM replacement.
Having said all that, I use Autolite platinum plugs in the 351 Windsors in my boat because they are a PITA to change. I use Magnecor wires because I have EFI and can't tolerate any ignition related noise.
Robert
'95 Ford E150 4.9L I6 Megasquirt MS1 Custom MSnS Extra
'92 Winnebago Elante 33 RQ Ford 7.5L V8 Megasquirt MS1 Custom MSnS Extra
'93 Bayliner 3288 Twin Ford 5.8L V8s (351 Windsors) converted to tuned port EFI. Megasquirt MS1 Custom MSnS Extra
Do Pulstar Pulse plugs work? Z man DIY / How-to 94 12-29-2013 10:51 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
DIY - Spark Plug Indexing SVOboy DIY / How-to 40 05-21-2009 12:58 PM
Plug wires, rotor and cap. Does it matter much? lyd DIY / How-to 6 10-14-2008 09:41 PM
DIY - Wire Tuck SVOboy DIY / How-to 4 01-25-2008 02:14 AM
