Old 09-10-2008, 04:32 PM   #11 (permalink)
Icarus - '011 Mustang GT
90 day: 20.71 mpg (US)
NGK non-suppression plugs, and premium wires. You are not looking to remove resistance, but resistivity, which is resistance in relation to diameter. Iridium and platinum are good for longevity, as previously stated. Splitfires suck (in every vehicle I've ever tried them in at least - 6 of them). I've had good luck with AC Rapidfires - on high performance ignitions at least. I currently run NGK non-suppression Iridiums - my car doesn't take wires. I would recommend Taylor 10.4mm wires if they have a set for you, if not, get minimum 9mm wires - highest quality you can afford...
Old 10-29-2010, 01:31 PM   #12 (permalink)
Aveo - '08 Aveo LS
I'm using NGK iridium IX in my car... I bought a 2008 aveo with 34k miles on it... its stock coppers were horrendusly roasted... the iridium IX gave a notable improvement.
Note, most of the improvement was just "new plug" and not iridium
the NGK IX is rated for 60 thousand miles, and is a low voltage plug... that means its better for cold winter starts (which I need in chicago)
Once the engine is warm... if the plug burnt to hell... it doesn't make a difference
Old 10-29-2010, 03:18 PM   #13 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...don't believe that "low-resistance" wires will help your FE. While "low-resistance" wires were popular with the hot-rodders, they tend to create LOTS of "ignition-noise" STATIC which your radio will loudly announce to the listening audience.
...additionally, too little wire resistance is also detrimental to maintaining optimum inductive-discharge spark-duration time -- it effectively lets all the spark "arc" energy dump to ground almost immediately, rather than maintaining the "arc" duration for about 1,000 microseconds by "metering" the current level discharge by the coil-secondary/wire RL-time constant.
DIY - Spark Plug Indexing SVOboy DIY / How-to 40 05-21-2009 12:58 PM
Green spark plugs? WhenGrantAttacks EcoModding Central 3 07-11-2008 05:10 PM
Halo Spark Plugs..... Impulse EcoModding Central 7 06-26-2008 08:39 AM
Would a different heat range of spark plugs help FE? Chris D. EcoModding Central 3 03-17-2008 08:03 AM
Halo Spark Plugs DifferentPointofView EcoModding Central 1 01-28-2008 11:13 PM
