Old 12-21-2009, 03:13 PM   #11 (permalink)
YUK TRUCK - '93 YUKON GT
hello all more of a lurker but thought i post on this on and i think "funny" pretty much nailed it.
i used to work for a GM dealer as a tech we had a customer than delievered trailers he ran one ton trucks pulling trailers delievering cars,van.smaller trailes ect. he used gas and deisel engines and of course wanted to get the most life,power and economy he could.
i believe it was a 02 with a duramax that has such a oil life monitor, which does actually monitor driving habits and conditions.but he wasnt sure about it so we took oil samples and different milages, computers says 50% left,25% left 0 % left and sent them to a lab not sure where i wish i could remember but they came back within a % or 2 of the monitor this was using regular oil he would go 7-10,000 this was towing highway miles.
but i would agree on a new engine or new car to change it around the 1000 mile mark and early the first few times then follow the monitor. regular oil changes are cheap but of course we want to save oil and money.i am also a fan of synthetics
Old 12-21-2009, 04:28 PM   #12 (permalink)
Why would GM do such a thing (like recommend what looks like long change intervals)?
1. There are plenty of yahoo people out there who don't do ANYTHING to, or about their engine oil until something happens, usually bad. For them, this would mean changing the engine oil a lot.
2. Oil is a lot better these days, so some sort of engine analysis could be argued as very needed today.
3. In order for your engine to break in properly, a certain number of metal peaks must be worn down or smashed off, microscopically. So, SOME wear is not altogether a bad deal. Failure to wear in can be, in some ways, just as bad. So the engineers came up with some happy compromise number. Me, I would change every thou, for 3 thousand miles.
4. As a marketing tool, this is different. OOOOOhhhhh, must be something complicated and scientific! Marketing people eat that stuff up.
Finest regards,
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
Old 12-21-2009, 04:46 PM   #13 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
That is why i use the odd/unusual/strange changing interval, because of my previous work on engines.
I know that the majority of engine wear is in the first few hours of run-time on an engine, therefore I change out the oil that is getting filled with particulates. Then I go a little longer with a controlled particulate (Marvel Mystery Oil) to smooth the surfaces. Then I let nature take back over, but still change the oil more frequently to get the remaining majority of fillings out of the crankcase. Then regular oil changes with a good filter and good oil.
It just seemed logical to me, so that's why I did it that way.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 12-23-2009, 03:39 PM   #14 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
I opt for more often oil changes since I abuse the hell out of my stuff with weekly drag racing....even the Geo a couple of times. Oil not only lubricates, but also takes away impurities from combustion. I have always gotten 100,000 miles out of the motors of the cars I drag race by changing the oil at 1000 miles after purchase (if new) and then every 2000 miles with regular oil...or now every 5000 miles or once a year with FULL synthetic. Don't waste your money on synthetic blends because they are most often only 20% synthetic. My Geo Metro 3 banger and the wife's 05 4.0 Mustang V6 uses the least amount of oil of all.....in 2000 miles they use 1/4 qt of oil with regular oil and with 10-30 full synthetic they use 1/2 qt in 5000 miles. My 12 second SRT4 Neon uses 1 qt in 5000 miles. The old 84 Horizon is the least efficient...in mpg too....of course, the motor was given to me at the start of 06 with 235,000 miles already on it and it was using about 1 qt every 1000 miles, now it is up to 1 qt every 200 miles....but not smoking yet and a small leak from the oil pan sealing does not help. The Neon is near 70,000 miles as is the Mustang....the economical Geo is nearing 175,000 miles!
38 time NHRA/IHRA drag race champ
05 SRT4 / 12.17@117 mph on DOTs / 33.0 mpg
84 Horizon / 1760 lbs / 24 mpg
95 Neon / 46 mpg
2011 Prius / 62.1 without trying!
The Following User Says Thank You to ATaylorRacing For This Useful Post:
Funny (12-23-2009)
Old 12-24-2009, 06:58 PM   #15 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
sometimes the metal frags end up feeding it back at it. a combustion chamber is an amazing thing...it eveninvented a type of forging just by existing. (some compaines know how to use it- especially inline fours)
if worried about it, add a stronger filter. oil change needs trust in the chemistry...
castrol edge and other extremes claim 15k miles.
regular much less.
Old 12-24-2009, 10:29 PM   #16 (permalink)
Hydrogen Nut
Ptero's Avatar
Smart Car ForTwo Pure - '08 Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 V12
Wildfire 250C - '08 250C
Always use a quality filter ($$).
Change your oil at 800 miles.
Change again at 3000 miles.
Replace fossil oil with a synthetic blend at 6000 miles.
Again at 9000 miles.
Use pure synthetic at 12000 miles.
At 15,000, use pure synthetic again.
Change every 10,000 miles thereafter.
If you hypermile, your engine will outlive you.
Old 12-26-2009, 02:12 PM   #17 (permalink)
I recently bought a new 2009 Aveo. As soon as I brought it home I checked the oil. Good thing I did: it was a whole quart LOW. (The oil was new and so clean it was hard to see it on the dipstick. Needless to say, I added the missing quart.)
My use is all city driving, so I change the oil in my cars every three months regardless of mileage. You'll never go wrong by changing oil too often. It's changing it too infrequently that kills engines. And some engines eventually end up burning oil no matter what you do - but that's another story...
Old 12-26-2009, 04:47 PM   #18 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Wrong.
Old 12-30-2009, 06:28 PM   #19 (permalink)
Originally Posted by Jammer View Post
From what I can gather, I am unaware of any other brand of car using a computer to calculate the time to change the oil- Am I wrong here?
Yes, you are. BMW and Honda are two others that I know of, at least on some models.
As far as I can tell, they take "normal operating conditions" into account. They look at loads, temperatures, the time the engine is on, probably RPMs, and other stuff. I don't think they measure the oil directly in any way, so they don't take into account all of the stuff that accumulates in a new engine as it wears in.
I'm also more inclined to waste a little oil just in case it helps cut down on wear, so I would probably change the oil before the computer said to, until I thought the engine was "broken in".
-soD
Old 12-31-2009, 09:52 AM   #20 (permalink)
Funny's Avatar
"Full" Break-in doesn't occur until about 20,000 miles, depending on the break-in conditions (described at length and with much zeal above). That is the time on the engine that the seals will be the tightest and therefore the engine its most efficient. We Ecomodders are just looking to extend the "tightness" of the engine as long as possible.
I knew a lady that NEVER changed her oil in her cars, EVER. Not since she got it. She would always trade them in before 100K miles, because the thing was "not the same as when I got it". I told her that doing regular maintenance was important and she just kept doing the same thing she always had. Some people you just can't reach.
I on the other hand, would rather be safe than sorry.
American by right
Ecomodder by choice
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Spreading the word...one car at a time... mcrews EcoModding Central 23 12-29-2009 09:21 PM
