Old 10-16-2009, 05:36 PM   #21 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
newhavenpatriot, I sympathize with you about CT drivers.
One technique I've been playing with lately is trying to load the engine more effectively by tricking the transmission into upshifting by lifting off the throttle, than adding as much throttle as I can without causing it to downshift back to the previous gear. It's really a half assed solution though, a manual is key to loading the engine effectively. I test drove a car with a stick recently, and fell in love with how easy it is to do. I'm itching to get a new (used) car with a stick, but I happen to be very picky with cars, so I have to be patient.
More choices...
Old 10-16-2009, 08:30 PM   #22 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
A trick I learned with non-e transmissions is to adjust/remove the kickdown device. This will disallow the transmission from downshifting at all, though, so whatever gear you're in, you're in, until the governor takes you down a gear. You can manually upshift at a much lower RPM, though.
The kickdown (TV cable, in come cases) relates the Throttle position (relative load) to the transmission governor.
automatic, automatic transmission
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Locking an automatic in a single gear? bennelson EcoModding Central 11 11-14-2008 01:03 PM
Ecomodded Kia Ceed. Factory fit ecomodding!!! Unheard EcoModding Central 15 09-18-2008 08:31 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 03:10 PM
