03-27-2011, 11:43 PM
#91 (permalink)
wow pretty cool
U GOTTA BE CRAZY TO KEEP FROM GOIN INSANE AND IM ON THE KNIFE'S EDGE
04-09-2011, 03:30 PM
#92 (permalink)
Yeah now I am get 18.75 mpg but it hate city traffic.
I believe I have couple bad injectors it have burnt fuel smoke when floor on highway.
I tried block radiator. That does work BETTER EXPECT oil pressure gauge keep flick zero psi but engine doesn't make sound.
How you found manual gear box for F250? mine is bad it drip power steering oil.
I really need alignment it badly.
04-09-2011, 09:07 PM
#93 (permalink)
live, breath, Isuzu-Ds
if the steering box is a ford oem type, it would have to be from a early 70s ford or older if i remember right.
by the late 70s, 3/4 and 1 tons where P\S only please correct me if not right  i think im right
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED  NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
04-12-2011, 01:10 AM
#94 (permalink)
Found the manual steering gear at a local wrecking yard.
I believe MS was an option through the 6th generation run at least (up to 1979) but I could def. be totally wrong.
Originally Posted by Piwoslaw
A few months ago I returned home just as my neighbor pulled into his driveway. It was cold (around freezing) with some rain and sleet, and he yells to me: You rode your bike? In this weather?!?
So the other day we both returned home at the same time again, only now the weather is warm, sunny, with no wind. And I yell to him: You took the car? In this weather?!?
04-12-2011, 10:49 AM
#95 (permalink)
Moderate your Moderation.
If it's the same steering box as an F-150, manual boxes were available until about 87.
08-03-2011, 06:27 PM
#96 (permalink)
Recently came across a truck for sale that reminded me of this thread. Looks like a truly great deal at $5k (seems too low). For sale near Houston, TX:
I have a running 1988 Ford F350 custom crew cab rescue truck for sale. It has a strong 6.9L International Diesel motor with a 5-spd manual transmission. It has a custom made flawless aluminum cargo box worth a lot . . . A plumber or an electrician will find a lot of use for it since it has place to mount an electric generator with a fuse box and all sorts of connections and outlets all over the truck. Reasonable offers will be considered. Please call (832) 665 3568 for more pictures or information. Also, it has only 8000 miles on it since it operated on a small chemical plant and has never been used outside. Title is clean and has been owned by only one company.
1988 F-350 Rescue Truck with Box
The enclosed box is tall, relatively. Made me think of alternate ways to make money with a good home-made biodiesel truck candidate:
Mobile CNC Truck
Mobile 3D Printer Truck
A PTO-mount hydraulic motor can drive a generator AND a compressor. Add a heat-strip equipped A/C to the roof.
 2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
08-03-2011, 08:05 PM
#97 (permalink)
Mobile CNC Truck
I've got a chelsea 6 bolt pto if you need one.
