02-23-2013, 09:32 AM
#11 (permalink)
Originally Posted by wmjinman
I seem to notice the opposite effect - I'll be getting a particular MPG for a tank, and then fill up, all excited to improve upon it (warm engine, etc.), especially on a trip. But the ScanGauge will show much LOWER mileage for the first few miles. Seems like I can get it to start climbing eventually, but not at first.
I do try to top off the tank until it won't hold any more, thinking that's the only way I can be sure it's the same each time. Is this somehow wasting gas (burning extra out of the carben cannister & running rich, or something).?
Your short trip mileage will be hard to beat compared to your tank mileage in the first few miles because you have only been running a few minutes on the tank, vs many hours. I have run over 20 hours on a tank (1200 minutes).
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
02-23-2013, 10:18 AM
#12 (permalink)
Originally Posted by Cobb
Its because the filter on the hose contains magnets and they help to align the atoms inthe fuel as it enters your tank. Then the charge wears off the next day and your performance is less?
That's why the magnets on the filler hose is a bunch of snake oil. Anyone with half a brain knows you need to put the magnet on the fuel line as close to the injectors as possible.
The Following 2 Users Say Thank You to pete c For This Useful Post:
02-23-2013, 10:44 AM
#13 (permalink)
Well, the good fuel economy effect was discovered on insightcentral that you over filled the tank spilling fuel into the characoal canister and it helped to enrich the mixture of air into the engine, so it used less fuel from the injectors and the system read higher than normal mpg.
When my father bought gas for me I always over filled my car and never notice any of this. I just like to tease my former co workers that I can go 175 miles before the needle moves off the full mark.
02-23-2013, 04:00 PM
#14 (permalink)
I have noticed this too. The first few miles after filling up show much better fuel economy on my Insight's freshly reset running average. It's not just numbers. The car feels that it is doing more with less throttle. I suppose it could be from a vapor rich charcoal can.
02-23-2013, 05:04 PM
#15 (permalink)
Wow, that's weird. Now I'm really curious as to why I'm seeing the opposite.
Or maybe it's just the old deal of where people tend to remember the bad events more than the good ones. ? ? ? ? ? ? ?
But if I got 45 at fillup, and then take off from the gas station, and in the first 20 or 30 miles of highway driving, look at the ScanGauge hoping to see better than 45, it seems like it's 39 instead. (!!!) And I'm thinking, "Gee, and this was all "highway" driving so far, too". (except for the initial acceleration from the gas station)
02-23-2013, 05:08 PM
#16 (permalink)
That would mean that the discrepancy between the FE from the MID and the fuel pump/mileage ratio would be larger if you max the fill than if you don't.
Sounds reasonable enough though, and we know there is a spillage recovery system. My guess is that the gas contains some very light components that evaporate over time and get sucked up by the recovery system, enriching the mixture while evading the MID's equasion. After a day the lightest gases are gone and so is this effect.
My home had a pair of magnets on the main waterline when I bought it, so the H2O molecules got aligned to give better fpg from the loo (just guessing here). Sadly, as my brain has 2 halves, I felt like removing them so my loo now no longer has any boasting rights.
02-23-2013, 05:09 PM
#17 (permalink)
The high economy effect only seems to last for a few miles.
02-23-2013, 05:13 PM
#18 (permalink)
Originally Posted by RedDevil
My home had a pair of magnets on the main waterline, so the H2O molecules got aligned to give better fpg from the loo (just guessing here). Sadly, as my brain has 2 halves, I felt like removing them so my loo now no longer has any boasting rights.
LOL!!!
02-24-2013, 12:30 PM
#19 (permalink)
I see this effect quite often, but do you suppose it might have something to do with the fact that when I leave the couple of places I most often get gas, I'm going downhill for quite a ways?
