Old 06-06-2010, 09:55 PM   #1 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Better Passive Ventilation?
Has anybody tried installing a better passive air vent in their vehicle? Like adding exhaust vents out into the low pressure wake at the back, and/or adding intakes from ahead of the radiator? If the intake tied into the existing vent system, then the warmer air that seems to happen with the intake at the base of the windshield could be avoided.
Thoughts? Questions? Hints? Experience?
Old 06-06-2010, 10:39 PM   #2 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
I've seen it discussed a couple times, but I'm not aware of anything actually attempted. One thing to consider is exhaust fumes behind the vehicle. Make sure you've got positive airflow from front to back in any system you try.
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 06-06-2010, 10:42 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
If you take a look behind your bumper cover, I bet you'll find HVAC exhaust vents under there. The ones at the rear of the Insight move about as much air as the dash vents (no surprise there), and they exhaust into my trailing wake.
As to the intake, I bet the vent cowl is pretty cool when the car is moving, but you could spray-paint it gloss white so it doesn't get hot when you park.
Old 06-06-2010, 11:00 PM   #4 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
I think of vents all the time. My sube was egr disaster'd and rusted, and hydrocarboned, hypergoliced, electrocuted, and a metallic paint with garnet in it is not helping...
my dads rig makes my car and its puniness even tinier...
the vent to neutralize the rigs cabin (avoid ears popping) can fit my foot through it, and it is setup in a way to know outside is right there...no 14 liter diesel heat soakage in the way.
this auto neutralizing, as it turns out is even in my old subaru...vents can refuse to close, and with vacuum hooked up know when to sneak open.All hills related, angle of car... Mindboggling little trick they got going on there...
I learned it is illegal if that "trick" does not work BTW.
I did get frustrated about the sense of oepn the rig had, my car did not. I was doing 85 on the highway one day with vent open, and stuff came flying in, from a hardwood tree, leaves, etc. It finally opened, I have no complaints.
very fresh, no interference.
I also found by natures way some rust holes to simply clean up in my outrageous welding pursuits...and never ever close them...allows cabin to flow, down low...I like to think I added my own sneaky airways of clever.
these problems are 1980s and older related, and japanese. Today it is much smarter.
Old 06-06-2010, 11:35 PM   #5 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Too bad the old covered cowl vents went away
Then there were the ones down by the front passengers' shins- they were quite good too
Then there were the wing windows- all quite good
Now nothing but a/c
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 5824 Yesterday 04:25 PM
The Homemade Heat Pump Manifesto... AC_Hacker Introductions 23 11-08-2010 08:08 PM
do ventilation intakes add to drag? lunarhighway Aerodynamics 7 05-26-2010 01:57 PM
Passive Turbo easy EcoModding Central 21 12-01-2008 09:45 PM
Efficient attic ventilation Daox Saving@Home 8 07-18-2008 09:31 AM
