Old 04-30-2012, 06:55 PM   #21 (permalink)
I had a 4 stroke bike motor... loved it. Sold it when I ecomodded my commute down to 2 miles from 25 miles (yes, moving close to work was deliberate and the BEST DECISION EVER)
This is my review - Cool Tools: Golden Eagle Bike Engine
Work From Home mod has saved more fuel than everything else put together.
Old 09-11-2017, 11:07 AM   #22 (permalink)
Well you are thinking absolutely stunning of adjoining the bicycle with chainsaw, great idea.
Old 09-11-2017, 11:27 AM   #23 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Leave the poor dead horse alone!
Old 09-11-2017, 02:18 PM   #24 (permalink)
First read the DMV laws for your state and locality. I have a chainsaw based motor kit from the 1980s that is friction drive. It is legal in PA but not NYS The engine is a 34 cc 2 stroke design that was bought up by Poulan. It was rear mounted but front mounts engage better. Bicycle chain is 1/2" pitch so if the clutch works, use it. Gearing is the issue. An engine may turn 5000 to 7000 rpm but the wheel only 200-300 rpm at 20 - 30 mph. Do the math for your components. A jack shaft reduction system may be needed. A motorcycle throttle and a kill switch are needed. Make sure the tires and brakes are in top condition. An air filter for the exhaust will reduce the smoke and noise. The newer the engine the better the emissions reduction. A good frame mounted fairing and tail box will cut drag. If designed right the engine heat can be directed away in the summer and used for heat in the winter. A small fire extinguisher might come in handy, just in case.
Old 09-18-2017, 06:08 PM   #25 (permalink)
FWIW You can buy Wizzer kits on Ali-Express. Fairly well priced and all the parts included, an old schwinn or a 10Speed is a good candidate..
If it has a motor its worth playing with.......
Old 09-19-2017, 06:08 AM   #26 (permalink)
90 day: 35.79 mpg (US)
I love how this thread was brought back from the dead by someone with only one post. A shelf account?
hybrid bicycle with electric CVT? NiHaoMike Alternative Transportation 11 01-25-2009 06:06 PM
I took out a guy on a bicycle with my truck.. Chris D. The Lounge 16 11-01-2008 10:00 PM
Making an electric bicycle (looking for advice) NoCO2 Alternative Transportation 44 06-04-2008 02:54 PM
So you DO need collision insurance for a bicycle!!! Peakster Alternative Transportation 11 05-14-2008 12:32 AM
Road Bicycle Buying Advice Gone4 Alternative Transportation 67 02-26-2008 08:40 PM
