Old 11-07-2009, 06:32 PM   #31 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
I turned the A/C around once but dont know if it made a difference. too small to be measured i"m sure.
On my 5th a deflector on the truck roof netted almost 2 MPG.
To make it removable I started with a suction cup and straps type of roof rack from a yard sale. I think you may find them under those turtle toppers.
I made the supports out of that pre-drilled angle stuff so I could adjust it. A half sheet of plywood made up the face.
Makes a nice place for advertising/family crest/whatever too.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 11-07-2009, 10:04 PM   #32 (permalink)
bondo's Avatar
Colani Truck
Originally Posted by Christ View Post
Where's that Mercedes bubble thing Semi truck? The odd one w/ the huge glass spherical cab...
Sexy Concept Trucks By Luigi Colani
Here you go Christ. Luigi Colani is a true sculptor of air.
Bondo
The Following User Says Thank You to bondo For This Useful Post:
Christ (11-07-2009)
Old 11-07-2009, 10:27 PM   #33 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
That just might be it.. I think maybe I thought "Mercedes" because of the tri-wiper in the windscreen.
Old 11-19-2009, 09:20 PM   #34 (permalink)
I need to get pics, but got a few things done.
I bought a used Leer camper shell. It is the tallest one made. It is about 8" taller than the cab of the truck. Still need to get air up another foot and a half or so. I'll try to dig up a deflector for that. I also want to put some sort of wings on the rear/side of the truck to direct the flow away from the gap and out some. The trailer is wider than the truck.
I also made a lexan grille block and put foam in all openings under hood and around headlights.
Lexan skirts for the trailer are next. Still trying to figure out a boattail that won't be too intrusive to trailer use. I'm thinking a piano hinge and thicker lexan would work good and be easy to fold out of the way when I have to unload.
2010 Focus SES
2000 F250 7.3l with 20x8.5 enclosed trailer(the project)
Old 11-20-2009, 01:14 PM   #35 (permalink)
Hello,
I am just brainstorming here, but what if you filled the gap between the trailer and truck with a giant air ballon/bladder that stretched? As you turned, it would compress one side, but expand/stretch the other side. Would that work?
Doug
Old 11-20-2009, 01:43 PM   #36 (permalink)
I'm still thinking about that part. I thought about some "spandex" like material. I would just install snaps on camper, truck sides, and trailer. It would be easy to install or take off, yet still allow for articulation. I have a weight distribution hitch, so I can't turn super sharp with it anyway.
Originally Posted by ldjessee00 View Post
Hello,
Doug
2010 Focus SES
Old 11-20-2009, 05:04 PM   #37 (permalink)
Front mods. Grille block. Tape around headlights and under hood.
2010 Focus SES
Old 11-20-2009, 05:05 PM   #38 (permalink)
Camper pics. It still needs a deflector.
2010 Focus SES
Old 11-20-2009, 07:02 PM   #39 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
That looks great. Love the clear grille blocks and everything you intend to accomplish! I am not an expert on TD engines but I would think since you are towing a fairly heavy trailer and you closed off a substantial portion of air to the intercooler that you might want to monitor your charge air temperature. I think you guys do that with the end result out the back end with a an EGT gauge right? If you don't have an SGII get one or add an intake air temp gauge into one of your intake tubes. After the intercooler of course. If temperature becomes an issue you could make a simple scoop under the bumper since those trucks are "dirty" to the air anyway underneath it would not negatively affect your progress. Like I said I'm no pro just a friendly neighbor looking out for a guy. Those Powerstrokes are not cheap I would hate to see you pop it.
1996 Pontiac Bonneville SE 3.8L V6
Old 11-20-2009, 08:27 PM   #40 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
That looks like a significant improvement.
If it were me I'd put a boat tail on the roof top A/C with a light weight hinged top portion that could be spring loaded so that the slightest airflow would open it and forward motion would close it tightly. just a thought.
Subscribed.
6 speed ALH TDI
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
HYPERMILING & TOWING: A Misconception slowmover Hypermiling / EcoDriver's Ed 27 12-14-2011 07:20 AM
I build a 4x4 Gas-Electric-Hydraulic Hybrid! bennelson Hybrids 5 02-10-2010 12:53 PM
Efficiency When Pulling A Trailer grease87 General Efficiency Discussion 30 07-26-2009 12:07 PM
'98 Dodge Caravan 3.0L - 26 mpg pulling a trailer & 24 mpg pulling another car :) MetroMPG General Efficiency Discussion 7 05-25-2009 12:27 PM
