Old 10-08-2009, 01:10 PM   #21 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Originally Posted by TheSilverBullet View Post
very nice paint job !
I agree, and I think we are "Mature" enough to see the right side.
I, for one, got my curiosity piqued when you mentioned that.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 10-08-2009, 03:13 PM   #22 (permalink)
micondie's Avatar
moby van - '03 Caravan SE
90 day: 19.74 mpg (US)
For better aero you could look into a wing over the cab like 18-wheelers use to direct air flow up and over the box. Judging from how many I see on the road this must be effective since I can't imagine the big trucking companies spending the money for nothing
Old 11-14-2010, 10:21 AM   #23 (permalink)
- - '010 Prius III w/Navi
Sorry if somebody has suggested this already - can you chop the cargo box? What is your absolute min cargo height requirement ?
Old 11-15-2010, 07:40 PM   #24 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
OK. Where to start?
I don't think 20 MPG is in the cards unless drive at speeds that would get you shot/arrested on the Grapevine. But you can get improvements.
At 5 MPG I'd bet you are wildly overgeared. Probably a 4.56:1 axle. For that truck maybe you should think 3.73:1.
Check your brakes. Sintered metallic brakes rust on the edges and swell up, causing drag. Easy to check. Jack up the front end and give a wheel a spin. If it spins easily, that isn't your problem. If it stops in less than 2 revolutions remove the brake pads and use a grinder to chamfer off the edges. If one drags, probably all four drag.
The wing thing on the cab is effective. You need to fair in the undercarraige, especially under the cab. A proper boattail might be 590 feet long.
If you don't want to come down long grades like a Dauntless at Midway, a US Gear exhaust brake will help a bunch.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 11-15-2010, 08:55 PM   #25 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
IF the radii on the front and top of the cube are large enough I wonder if a cab deflector would do anything. Those deflectors are mainly for shooting the flow over the tractor-trailer gap, of which there is none here.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
