bike build
Anybody want to take a guess how many miles I'll get to the tank with my bike?
kawasaki zx10r build. - YouTube stock engine, e85, 10psi :turtle: |
On E85? 6mpg, maybe 15 if kept to the speed limit.
Running E85 on it with the stock engine? Man, in my country the folks already freaks out about the E25 :p
From what I understand, you can get about 25% improvement running ethanol ONLY if you have compression ratio in the 14's!?! I'm trying to get my vehicles to around that compression and with torque cams to try increasing low end torque and fuel economy!! I also want to see about making my own fuel!!
From what I understand, you could get about 25% improvement strolling ethanol ONLY when you have compression ratio within the 14's!?! I'm seeking to get my cars to around that compression and with torque cams to attempt increasing low give up torque and gasoline financial system!! I additionally want to peer approximately making my personal gas!!
Some dedicated-ethanol cars in Brazil resorted to high-compression pistons in order to achieve that. But actually there were other models with lower compression which ran well on ethanol. BTW one of the engines still regarded as the better suited to ethanol, the Renault-based Ford CHT engine, had a 12:1 compression ratio.
Interesting build. How's the performance though?
