Old 10-15-2017, 10:13 PM   #21 (permalink)
If that's true, that's really awesome for the notched V-belt. The advantages sure would outweigh the roller chains.
Old 10-15-2017, 11:41 PM   #22 (permalink)
It is likely cheaper to manufacture a sheave system than to cut a bunch of gear teeth.
Old 10-16-2017, 01:23 AM   #23 (permalink)
Stubby79's Avatar
Topoff (RIP) - '92 Geo Metro LSi
90 day: 48.54 mpg (US)
'91 Miata - '91 Mazda Miata
90 day: 27.11 mpg (US)
'86 Fiero GT - '86 Pontiac Fiero GT
Purple Penny Pincher - '95 Pontiac Firefly Base
90 day: 43.68 mpg (US)
Jett-Black - '01 Volkswagen Jetta
90 day: 39.32 mpg (US)
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
If you ask me (even though you didn't), the way to go would be to have a CVT for getting up to speed, and then be able to switch it in to a fixed gear once up to speed.
I also assume the reason belt driven CVTs are only 80% efficient is slippage, which is the main reason friction belts are less efficient than chains, and why a timing belt is not. The other losses come from flexing/compressing/decompressing the rubber.
Old 10-17-2017, 11:38 PM   #24 (permalink)
A dual belt system with a V belt over a timing belt and a timing sprocket at the drive and the base of the sheave. Hmmm
Old 11-13-2017, 03:38 PM   #25 (permalink)
ASV
weirdo
ASV's Avatar
i believe the most common problems with the gy6 CVT are
the constant movement of the belt
(the clutch is on the wrong end)
and gearbox final drive
( each gear interaction cost a few percent efficiency)
I would move the clutch to the drive pulley like a comet.
A giant 17 inch serpentine pulley on the back wheel and a 2 inch
pulley on a real swing arm axle jackshaft
it would weigh less handle bumps better
and be more effective
The Following User Says Thank You to ASV For This Useful Post:
Grant-53 (11-13-2017)
Old 01-02-2018, 11:34 PM   #26 (permalink)
tinkerer
I have a bit larger bike I have tried using a flat cog style belt to compare to a sealed roller chain mind you this is final drive not in the transmission. This set up lost a average of 1.25 to 3 mpg on a 83 550 Yamaha Maxim. I tried thinking the weight reduction would help however it didn't. I put back on my chain after trying several adjustment. I even went as far taking drive pulley off and machining as much mass off as i thought remotely safe to do. http://www.cyclingnews.com/features/...ve-whos-faster found this link when i was trying to figure why.
The Following User Says Thank You to johnny77 For This Useful Post:
Grant-53 (01-03-2018)
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
