Old 09-15-2015, 09:31 AM   #11 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Originally Posted by markweatherill View Post
In your engine? ...excellent detergent qualities if no other benefits.
Makes the exhaust smell springtime fresh too.
The Following User Says Thank You to wdb For This Useful Post:
niky (09-16-2015)
Old 09-15-2015, 07:49 PM   #12 (permalink)
101Volts's Avatar
Grandpa's Caprice (retired) - '84 Chevrolet Caprice Classic
90 day: 20.24 mpg (US)
Comfy Woody Wagon - '90 Mercury Grand Marquis Wagon LS
90 day: 14.13 mpg (US)
Suburban 6.5 T.D. - '99 Chevrolet K2500 Suburban LS
90 day: 12.94 mpg (US)
Hi-Ho Impala, Away! - '01 Chevrolet Impala Base
90 day: 22.46 mpg (US)
No. Though now that you mention it I wonder what would happen if someone tried that.
Old 03-25-2017, 07:39 PM   #13 (permalink)
101Volts's Avatar
Small update: I used Renewable Lubricants' 5w40 Low Ash Diesel Oil with an Amsoil EaO filter on the 6.5 Diesel and had no problems.
I only used it a little over 2k miles over a 6 to 7 month period however. Still, considering I took some of the unused oil and poured it on the ground and the grass regrew within a week it could be useful depending on your application. As for fuel efficiency this particular 5w40 is on the thin side (closer to a 0w40 than a 5w40) so if you switch to this you may see a MPG gain if you were using a thicker oil. Below I have linked the data sheet for this oil and their thicker Diesel 5w40 oil so you could check their viscosities:
Low Ash:
http://renewablelube.com/files/8914/...tor_Oil_LA.pdf
Non-Low Ash:
http://renewablelube.com/files/6414/..._Motor_Oil.pdf
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
