Old 04-07-2022, 10:25 PM   #1 (permalink)
The silver bullet - '01 Saturn S Sohc 5 speed
90 day: 40.84 mpg (US)
Saturn 1.9 sohc oil viscosity vs mpg
It's coming up onto time to do a service on the poor Saturn
I am wondering if there is the potential for some low hanging mpg fruit to go down to a 5/20 full synthetic over the 5/30 conventional I'm sure is in the car.
I plan to also service the manual trans was well.
Thoughts
Too much junk to list. From a 10mpg caddy limo to a 5 speed Saturn
Old 04-08-2022, 12:15 AM   #2 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Thoughts
No idea but apparently some tests show 1-3 percent improvement in mpg. Saw this at the store too versus regular synthetic
The Following User Says Thank You to Phase For This Useful Post:
Ecky (04-09-2022)
Old 04-08-2022, 01:37 AM   #3 (permalink)
Know the Saturn's requirements. are they finicky?
www.yourmechanic.com/article/a-guide-to-motor-oil-additives_2
Additives in motor oils
Motor oil typically contains a Performance Additive Package that can make up 15% to 25% of its composition. The remaining percentage is base oil. The additives help to enhance the performance and viscosity of the motor oil. Oil manufacturers design their products to comply with the specifications of car companies and engine manufacturers.
"We're deeply sorry." -- Pfizer
Old 04-08-2022, 07:43 AM   #4 (permalink)
They have a propensity to use oil profusely due to insufficient oil drain back holes in the pistons oil control ring groove. Mine is so so in that's respect.
So let's not act like the manufacturer actually had everything completely figured out in this case.
Plus it's a $600 car so....eh
The Following 2 Users Say Thank You to R.W.Dale For This Useful Post:
freebeard (04-08-2022), samwichse (04-08-2022)
Old 04-09-2022, 10:38 AM   #5 (permalink)
90 day: 40.51 mpg (US)
I'd at least drop down to a 0w. Best I can tell, it's superior to a 5wXX in every respect. I've known a few engines to burn a bit of oil when cold when dropping to a lower winter weight, but everything I know about oil tells me it should be doing a better job of protecting the engine, in addition to improving economy.
Old 04-10-2022, 10:05 AM   #6 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I would think that as the engine has aged, tolerances have increased not decreased? Also, full synthetic is downright cheap if you know where to buy. I get mine at Costco, $30 for (2) 5 quart jugs.
https://www.dragzine.com/news/what-i...l-viscosities/
