Blackfly XFi? Geo Metro economy cam shaft swap! Update: swap completed
[ A full report of this thread appears here: International heart transplant: the Blackfly gets an XFi cam - MetroMPG.com ]
http://ecomodder.com/forum/attachmen...1&d=1512066213 Thanks to a certain website overlord who shall remain nameless, I now have in my posession a camshaft from a Metro XFi (year and mileage unknown). This cam will find its way into the Blackfly's engine compartment in the not too distant future, replacing the extravagantly wasteful OEM cam that came with the car. http://www.gassavers.org/images/smilies/wink.gif Metro aficionados know that the XFi cam was one of several mechanical differences between that model and the garden-variety Metros, which cumulatively gave it a significantly better EPA rating: Quote:
I'd really like to do some A-B-A to get an actual number, but cam swaps at the side of the road on a hot engine may be problematic. Besides, the return of testing season is 3 months away at best. So I'm just going to install it and revisit the experiment question later. |
Won't the car also need an XFi computer?
No. It's a mechanical thing: the different cam profile - lower lift & duration - raises the cylinder pressure and shifts the torque peak downwards, so less throttle is required at low RPM. It lowers the XFi's HP rating from 55 to 49, but the torque value is unchanged (the RPM at which the max occurs is lower). (EDIT: The cam alone may not be the HP limiting factor - that could be ECU-related.) A number of people have done similar swaps including GeoMetry on this forum, and 3 that I know of on teamswift.net. I don't think any of them also swapped ECUs.[/quote] |
Reconsidering the ECU issue...
One thing the XFi ECU may do to compensate for the different cam profile is adjust timing differently. Higher cylinder pressure would mean more chance of pinging under high load / high temps. So a guess is there may be less advance in the XFi ECU under those conditions. Something to keep an eye on. Or an ear. |
Note that I've swapped transmissions and have a much taller final drive. So the cam swap with lowered torque peak should be a better match to the gearing I have.
The Actual Unit - 6 lobes of fury:
http://images6.theimagehosting.com/a...xfi-cam.th.jpg I'm itching to get this done, but it'll have to wait until winter retreats a little. It's -22 C / -7 F outside. That's frostbite weather, not Blackfly fixin' weather. |
One potential effect of raising cylinder pressure too high is pinging/detonation.
RH77 offers some detailed info about the implications: Quote:
March 11/07...
Swapped cams this afternoon. Warmest day of the year so far: + 6C, sunny & calm. OK for driveway tinkering! Haven't driven it yet (just started it up - sounded the same). I'll take it for a spin after supper and will report back... |
How, exactly does changing cam lift & duration improve low end torque?
I'll be the first to admit I'm no a cam expert. Everything I've learned, I learned online... recently. Such as:
I can't defend the decisions of the engineers who made the XFi cam. But the proof is in the pudding - the XFi gets better fuel economy. And I suspect the laws of physics were respected. |
A Metro expert suggested it would be perhaps a 30 minute job. It took me maybe 2 hours. It'd take me 30 minutes to do again though http://www.gassavers.org/images/smilies/smile.gif
1. I cut my timing belt cover with a dremel so I could remove just the top portion (the part that covers the cam sprocket). If you don't do this, you have to remove both the water pump pulley and the crank pulley to get the cover off (careful you don't cut the timing belt too!). 2. I was prepared for the challenge of getting the valve cover off. There are some spacer/gasket-y things under the nuts. They need to be spun off or the cover won't budge. 3. I had to go to a friend's house to use his vice (to hold the cam sprocket so I could get the bolt out and back in, tight enough). Need to buy a vice. Can't believe I've gotten away without one for so long. Having said that... WOW! I like it. http://www.gassavers.org/images/smilies/tongue.gifhttp://www.gassavers.org/images/smilies/biggrin.gif
So it certainly hasn't hurt! In fact, I think it's safe to say it's a perfect complement to the taller tranny. Like peanut butter and jelly! |
