Old 07-06-2011, 01:29 AM   #1 (permalink)
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Mustang GT
90 day: 24.7 mpg (US)
Lightbulb Blocking of the back side of a rim
I see many people doing pizza pan moon disks for the front of the rim. But has anyone done any attempts at trying to block off the back side of the rim? In my mind you couldnt really attach it to the rim itself but rather fix it to the suspension firmly and very close to the rim so it doesnt scrape. Im sure brake temps might be higher but not too many guys here are exercising their brakes enough for damaging heat levels to be considered. And im sure there would be a small gap to let some air into the rim. But i just think it would cut down on the rim turbulence in a big way if this could be done safely and effectively. It might even make the belly pans more effective.
2000 Mustang GT
273hp/ 309ft.lbs.
Cd 0.36 Im working on it
Old 07-06-2011, 01:46 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Floordford -
I think we had a thread on this a few(?) months ago but don't know where it is.
CarloSW2
American Solar Energy Society
Old 07-07-2011, 10:41 AM   #3 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
I don't see any advantage to blocking the back side of the rims. I would imagine that a belly pan that came close to the tires would do basically the same and would be easier to accomplish. As far as the front tires go, a set of wheel spats would minimize the airflow past the back side by deflecting it farther away from the tire. I can't imagine it would be worth the effort unless you have an open wheel car.
Old 07-07-2011, 03:52 PM   #4 (permalink)
How could that possibly help?
Old 07-07-2011, 05:27 PM   #5 (permalink)
Muscle Car Modder
Floordford's Avatar
The same as closing a window makes for smoother aerodynamics. The tire is disturbing the air and a plate to make the air path smoother would "help". People have been running covers on the outside of the rim for a while now. And a cover for the inside of the rim might help smooth the air under the vehicle so that it doesnt act like an open car window. I wasn't thinking of a ring to mount on the rim that would clear the brakes when the rim is taken off but more of a piece of aluminum that would attach to the suspension and be very close to the rim. Most cars with disk brakes already have a dust shield behind the brakes that is attached to the suspension. But I was thinking of something closer to the inside of the suspension that would make it to where the back side of the rim wouldnt effect the air going past.
2000 Mustang GT
273hp/ 309ft.lbs.
Old 07-07-2011, 05:39 PM   #6 (permalink)
skyking's Avatar
Woody - '96 Ram 2500 SLT
90 day: 20.74 mpg (US)
Avion and Woody - '96 Ram 2500/5th wheel combo
90 day: 15.87 mpg (US)
I think with the space needed to accommodate the brake, you have entered the realm of diminishing returns. The air is already "dirty" under the car, even with a good belly pan.
1996 Dodge 2500 Cummins Turbodiesel
Custom cab, auto, 3.55 gears
Old 07-08-2011, 12:30 AM   #7 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
Volkswagen does this - since about 2006
VW already has this
it is a real pain to see the rear pads from the inside because of it
Old 07-08-2011, 02:41 AM   #8 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
I have done that to my Seat rear wheels. Welded steel plates to suspension mounts. Cannot estimate the effect but it`s sure that i will help aero wise. No problems with brakes with smooth pizza pans + those. Every little bit helps .
https://skydrive.live.com/?cid=acb1f...!248&sc=photos
www.tuneko.com
Less drag = Less fuel
The Following User Says Thank You to Vekke For This Useful Post:
Cd (07-08-2011)
Old 07-08-2011, 04:39 PM   #9 (permalink)
Muscle Car Modder
Floordford's Avatar
Vekke, did you do any A-B-A kind of testing with them? I see you've done plenty of other mods.
2000 Mustang GT
273hp/ 309ft.lbs.
Old 07-08-2011, 04:46 PM   #10 (permalink)
inside MOONies
Lakesters at Bonneville use them.Really, all the fast open wheel racers.
Danika Patrick has them on her Indycar ( carbon fiber,very nice!)
I have considered doing this on the trailer.They would have to be mounted on the axle,as they wouldn't make it past the hub if on the wheel itself.
I'll do the lower-hanging fruit first and then if time remains,I'll cobble something together.
Ford's inner fender,along with the urethane rubber wheel spat on the Probe-IV was good for a 9 % drag reduction.It's the only 'science' I have for such a mod,but it clearly demonstrates a drag reduction when the wheel is 'cleaned.' And this is a full bellypan car with only 3-inches ground clearance!
If anyone is seeking really low drag,then this sort of mod is certainly 'on the table.'
