1. the blue lcds suck at night and don't provide as good contrast/readability during the day, I don't recommend it, but anyway:
2. the newer prebuilts come with a low power backlight (stn), might be another resistor rig to get the backlight right.
3. it is easier to cut the wires between the lcd and the guino then heat and remove the remaining bits, than it is to try to heat all the connections at once and seperate them.
4. cut the glue binding the board and lcd CAREFULLY, there are delicate circuit traces all around.
5. once you get the lcd seperated and the bits of wire removed from the guino, you should go over all the holes with an iron and a solder sucker to clean out the holes.
6. make sure you insulate the new LCD with some plastic in a sandwich. I used hot temp glue.
7. make sure you don't short out the connections on the lcd, there isn't much space between the pads. you can just heat and flick any solder bridges if they happen though.
