Old 09-08-2008, 06:11 AM   #1 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
BMW gets it! sort of
while people on this board prove every day that small inexpensive changes can have a big impact on FE, carmakers are slow to catch on.
still BMW these days has a number of interesting features in production that hopefully will soon be adopted by other car makers, but if nothing else, could sever as an argument next time someone redicules your cardboard grillblock etc.
theres some simplistic but cool animations that explain every feature
BMW EfficientDynamics : Air vent control
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 09-08-2008, 08:09 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I LOVE the idea of an actuated grill block. I have thought about how to do it numerous times and have a descent system worked up. The only problem I see is icing up in winter time.
Old 09-08-2008, 10:17 AM   #3 (permalink)
i'm working on my own simplified version of this... a single louver will be opened by a 12v motor when the fan kicks in... i've ran a static version of the grillblock at 30°C/ 86F exterior temp... and than the car started to get really hot so i had to take it off.
at 25C/77F engine temps are right where they should be with the block in place.
the only time when i see "normal" people use a grillblock is in winter , so i doubt you can make a car overheat than... but given the proximity to the radiator to the system i think it's got a great defroster behind it, should that be a problem.
what's the biggest hurdle is make something that works reliable enough to trust it to open when your fan kicks in... i'd wire up some led's to monitor the door but for not i haven't been able to build something that's reliable enough
Old 09-08-2008, 07:27 PM   #4 (permalink)
Tracy - '00 corsa
Temperature Activated Switch Kit > Maplin
this circuit might help
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 09-09-2008, 08:44 AM   #5 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Protege LX
90 day: 39.39 mpg (US)
The Golden Turd - '01 Grand Caravan Sport
90 day: 16.83 mpg (US)
as long as it ices up closed!
Old 09-09-2008, 08:54 AM   #6 (permalink)
@modmonster
i've thought of something that looks very similar, but i think i'd just wire ip up to the fan... if somethings wrong witht he fan it'll show on the dash lights and i could hook up a led to the fan fuse terminal that'd save me some wireing.
yesterday i discovered why my temps stay so normal with the grillblock... teh tape holding it shut had come off and the airflow can just blow the doors open....
keeping the door in the right position will be another thing to tackle... a worm gear might work as it won't allow rotations to be transfered back from the door to the motor... but it's hard to find good gears...
Old 09-09-2008, 12:15 PM   #7 (permalink)
common equipment on farm tractors built even before I was born, LOL (not for aero but temp control)
Radiator Shutters
Old 09-09-2008, 01:45 PM   #8 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
well, as for the icing in the winter..
if it doesn't work.. FORCE IT!!!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 09-09-2008, 03:06 PM   #9 (permalink)
Good for them! The T-100 is poised for this,however for now the ogival piston air valve is stationary.After my shop is further along,I can complete that project.Should help this winter,as along with the bellypan,I can close off the engine compartment when parked to conserve heat.
BMW M3: "The optimal speed for fuel economy in this car seems to be around 80mph" MetroMPG Hypermiling / EcoDriver's Ed 35 04-01-2011 04:09 PM
BMW cooling duct fabrio. Aerodynamics 19 09-27-2008 04:48 PM
Someone tell BMW that 28MPG for a car sucks dcb The Lounge 13 08-29-2008 11:53 AM
BMW vs Prius Sandy General Efficiency Discussion 17 04-08-2008 06:41 PM
Speed vs. MPG: 1996 BMW 318ti MetroMPG General Efficiency Discussion 0 01-24-2008 10:45 AM
