09-22-2013, 05:37 PM
#11 (permalink)
T-100 Road Warrior
Originally Posted by Xist
Is there any way that you could move the coffin forward? While more on my hypothetical Civic HX than on Bacon, I have thought about building a boat tail off of a trailer hitch--on Bacon, I could secure the top to the rear gate hinges, but I do not have any idea what I would do on a coupe. A single-wheel trailer, though, which only articulates on one axis, I would think that you could do a great trailer like what Aerohead is doing, but it would seem far simpler!
Once I start tearing down the trailer to replace the rusted fasteners, dilapidated deck floor, and what not, I can move it forward or even remove the cargo "coffin" and build my own. After looking at the fasteners, I really shouldn't have loaded it up with gear as most of them were rusted down where they could've easily failed and the cargo container would've fallen off.
Dark Aero-The world's first aerodynamic single wheel boat tail!
09-22-2013, 11:36 PM
#12 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
i have heard bad things about Harbor Freight tires, esp for trailers.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
09-24-2013, 03:00 AM
#13 (permalink)
All the articulation is in the receiver hitch? It's scary, dump it.
You need two custom brackets on or under your back bumper that attach the same as the crossbar/hitch piece does now. There are bronze bushings in there, right? That's the way all other one-wheel trailers do it.
How does the width of the frame at the rear compare to the truck? Flat-sided teardrop or compound curve bubble?
09-24-2013, 08:10 AM
#14 (permalink)
T-100 Road Warrior
I'm not finding the "bad thing" issues with the 8" Harbor Freight tires on the internet. I won't be loading a lot of weight on these tires any way.
Today I will snap a bunch of piccies of the trailer before I tear it down. Seems they used OSB fer the deck.
09-24-2013, 08:22 AM
#15 (permalink)
T-100 Road Warrior
No bronze bushings in the vertical supports...just holes in steel plate. I just squirted some oil to reduce the amount of squeak on the way home.
If articulation = slop...then yes. If articulation means it's supposed to move/pivot...then no. The single wheel pivots in turns...just like a front wheel fer a shopping cart. I think if I have the hitch adapter rebuilt with 2" stock, the rolling should be minimized. If that doesn't work...I'll have to see what it will take to stabilize the roll.
I need to fab up a way of locking the wheel in the forward trailing position when I don't have the trailer hooked up. Even though it has support legs in the rear, it doesn't work as well as one would think.
Once I have the trailer torn down, I'll be able to git the measurements and post them along with the piccies.
There's no way I could put brackets on my bumper as the tailgate would hit them when the tailgate is down.
09-24-2013, 03:19 PM
#16 (permalink)
T-100 Road Warrior
Stripped down...
Bad bolts...
Bottom side...
Dampener...
Shadow!
Hitch adapter...
Just a little bent...
Concept fer locking the wheel straight ahead...but I'll be using metal tubing or box tubing instead of wood.
The Following User Says Thank You to BamZipPow For This Useful Post:
09-24-2013, 06:49 PM
#17 (permalink)
T-100 Road Warrior
As soon as I git the hitch adapter fixed, I think a hitch anti-rattle device might work to keep the trailer from rolling. Looking at this one...Hitch Vise. Seems easy to install and adjust.
Hitch tightener: no wobble, anti rattle stabilizer device for hitch accessories
Ordered the Hitch Vise and it should be here by the end of the week or the beginning of next week.
09-26-2013, 12:08 PM
#18 (permalink)
T-100 Road Warrior
Deck measures in at 54" long by 36" wide. Gonna git some 1/2" plywood cut today and install it with some stainless steel bolts this time around.
Gonna see about having the hitch adapter converted over to 2" and not worry about any 1.25" adapters gitting in the way, too.
09-29-2013, 01:42 AM
#19 (permalink)
T-100 Road Warrior
Got my Hitch Vise devices on Sep 28. Nicely constructed from steel. Will test it in the morning if it's not raining too hard out.
Picked up my stainless steel fasteners and a gallon kit of Herculiner to coat the new plywood deck with. Not sure if I want to coat the frame or not...we'll see.
09-29-2013, 11:23 PM
#20 (permalink)
T-100 Road Warrior
