05-04-2015, 09:23 PM
#521 (permalink)
T-100 Road Warrior
Found a company that makes a single wheel trailer with an air ride suspension and a shock absorber on the swivel wheel!
VMH trailers LLC
At least I can say I'm the only one with adjustable air shocks on the hitch.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
05-05-2015, 08:04 AM
#522 (permalink)
Rat Racer
That looks suspiciously like a large Kong.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
05-05-2015, 09:38 AM
#523 (permalink)
T-100 Road Warrior
I know...
It's actually a double convoluted air bag spring.
The Following User Says Thank You to BamZipPow For This Useful Post:
05-09-2015, 07:14 PM
#524 (permalink)
T-100 Road Warrior
Made a run out to Hearne today with Dark Aero hooked up to try out different air pressures on the air bag spring. At 45 PSI, the ride was much more bumpier with Dark Aero unloaded. I tried out 30PSI and it was much smoother. I'll give 25PSI a try again and see if I can tell the difference or not (probably not). The air bag spring held pressure without any leakdowns during the quick run. It should be able to hold up fer the run to Houston next Saturday.
Running around town today, a lot more people got some more piccies of the rig and while others weren't sure what they were seeing. Occupants of a Prius were cranking their heads to try to figure out the setup and I could tell they were discussing how the trailer was gonna work or not work. Unfortunately, they didn't git to see the rig make the U-turn at the light.
05-13-2015, 12:51 PM
#525 (permalink)
T-100 Road Warrior
The Following 3 Users Say Thank You to BamZipPow For This Useful Post:
05-15-2015, 04:37 PM
#526 (permalink)
T-100 Road Warrior
05-15-2015, 07:03 PM
#527 (permalink)
It sounds like you passed a test. You could do some A-B-A testing.
Painted the bottom of the skid plate white and added in a rear brace to keep the rear flat. I think I might seam an edge on the front to keep it flat as well vs my current method of curling the corners up to keep it from tin canning. I will replace the self tapping srews with some bolts and nuts to reduce the potential of snagging something with the exposed shafts.
Make two wire U-shapes of length lx wx l, slide one in from each end, and treat the w edge as above (taped, or folded and taped).
And I'd replace the 'srews' with pan-head pop rivets with backing washers.
05-16-2015, 12:36 AM
#528 (permalink)
T-100 Road Warrior
I did notice that during my rain flow testing this afternoon, that when I drove into some water in the road, the pattern that I saw in the mirror wasn't a rooster tail but more of a pulse that was flattening on the road. I'll have to figure a way of shooting some video if I git another chance at it.
My trip to Houston is still on track with some potential severe thunderstorms along the way.
05-18-2015, 08:46 PM
#529 (permalink)
T-100 Road Warrior
Early Saturday morning run to Houston went well...only a few gawkers. No rain to play with at all. Stopped by the old stomping grounds and had breakfast at the Taco Cabana off of FM2094 and Highway 146. Had a few people "shark" around the rig fer a few minutes. Even the staff at the restaurant had to snap a few piccies of the rig. They've seen me before but I haven't been by with Dark Aero before.
Raided the grocery store and a few more sharks showed up. Continued on to the event and one of the sharks who spotted the rig at the grocery store found the rig at the event. He asked about the truck to a few of my friends who pointed me out but he never came over to ask. At least most of the kids at the event got some ideas planted in their young impressionable minds...
The return trip back home was brutal. New Kids on The Block was performing in downtown Houston and the traffic (people returning from the beach as well) was serious stop and go from my entry point to where the I-610 split off. At least I had a little breathing room...until the rest of the paparazzi showed up. They do some crazy things just to git some piccies of the rig. Had one sports car blow by me...slowed down in the fast lane (70mph?) to try to git me to go past him (I was in the far right lane) but I wasn't having that...so we ended up slowing down to around 30mph. I kept him in front of me until he had to speed away to keep from gitting rear ended.
Continuing on to Cypress, people were snapping away. The pattern became fairly evident. I drive past them, they pop/snap their heads to look (kinda like ground squirrels), and then the phones come out to try to snap piccies. Had one passenger roll his window down so he could lean out to snap piccies. Some dangerous moves on the road though.
Needless to say, my data from this run was really screwed up. I did git an indicated 25mpg at 65mph from Cypress to College Station. The skid plate didn't fall off or scrape the screws. I picked up some steel pop rivets today so I could secure the reinforcement bar a little better with those instead of the screws.
05-18-2015, 10:46 PM
#530 (permalink)
What went down in Houston?
Don't forget to back up the pop-rivet with a washer.
