11-05-2017, 01:27 AM
#941 (permalink)
So, does that light move sideways?
11-05-2017, 12:31 PM
#942 (permalink)
...like a broken grocery cart caster?
11-05-2017, 05:54 PM
#943 (permalink)
T-100 Road Warrior
Well, it moves with the wheel assembly.
Dark Aero-The world's first aerodynamic single wheel boat tail!
11-05-2017, 05:56 PM
#944 (permalink)
T-100 Road Warrior
Not that I'm aware of. I'm not seeing any light sweeping left or right as I'm driving down the road.
11-05-2017, 06:18 PM
#945 (permalink)
T-100 Road Warrior
I'm looking to disassemble and modify the light assembly. It only operated fer about 10 hours before it started flashing due to low battery power. I'll have to see if I can git a much longer run time by using a set of bigger batteries (D vs the current AAA). The batteries should be able to tuck into a compartment in the wheel pant. I should be able to easily to incorporate the light PCB on the end of the wheel pant.
11-06-2017, 12:48 PM
#946 (permalink)
You might look at 18650(18mmx650mm) size lithium batteries for incensed run time and small package . Lile this on eBay [url]http://www.ebay.com/itm/372059887230[6400w/url]
1 18650 will replace 3AAA with 10 times the runtime
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
11-06-2017, 02:45 PM
#947 (permalink)
T-100 Road Warrior
Originally Posted by gumby79
You might look at 18650(18mmx650mm) size lithium batteries for incensed run time and small package . Lile this on eBay http://www.ebay.com/itm/372059887230
Koolness! I'll give those a peek and see what I can do with those. Thanks!
11-07-2017, 11:12 PM
#948 (permalink)
Though those rechargeable lithium batteries seem to be a good idea, wouldn't it be worth to try to feed that light directly through the truck's own wiring?
11-08-2017, 03:57 AM
#949 (permalink)
Maby with a wirless carger but the wheel must b alowed to spin full circle witch would require a wiper/brush system.
Former
87' Hyundai Excel
11-09-2017, 11:37 AM
#950 (permalink)
T-100 Road Warrior
It's very early in my rear light build but ideally it would be great to tie into the rest of the lights.
