Old 12-30-2011, 06:11 PM   #1 (permalink)
EcoRod - '97 Sentra GXE
90 day: 37.72 mpg (US)
Boattail without boattailing
Is there a way to boattail a small sedan without doing a full on boattail?
Old 12-30-2011, 06:19 PM   #2 (permalink)
mostly harmless
Earl - '86 C10 Silverado
90 day: 11.31 mpg (US)
Herman - '06 HHR 2LT
90 day: 28.89 mpg (US)
Mount a force field generator in the trunk, and tweak the "shell" until it's about the right shape. Another effect is that the tailgater who doesn't stop in time may be vaporized by the field, but that's his own fault, right?
Old 12-30-2011, 07:01 PM   #3 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
I have been pondering an inflatable decklid extension for my Toyota Echo sedan. It could be controlled manually by a switch or automatically depending on vehicle speed. That way, it is less imposing (size-wise) when deployed and easily hidden when not needed. I believe that would be a good compromise and yield interesting results.
Here is what my car should look like when fully done !
Old 12-30-2011, 08:32 PM   #4 (permalink)
I think I will remove the bumper and turn it into a pan that flows to the trunk. I may shave the edge of the trunk lid down a little and see about shaving the sides of the car. I don't mind doing the boattail, just seeing if there were any other options.
Old 12-31-2011, 09:35 PM   #5 (permalink)
I've kind of wondered about the feasibility of a windsock style boattail. Something along the lines of a sea anchor, but fitted to the rear end of the car with just enough of an opening to fill it with air at speed.
Old 01-03-2012, 05:53 PM   #6 (permalink)
Is there
Kamm and Korff recommended cars with enough boat-tail such that the wake would be 1/2 the frontal area of the vehicle.That occurs at about 50% of aft-body boat-tail.Thie recommendation is based on 'practical' length for operating in traffic,negotiating streets,turns,curbs,ramps and parking.
Your design drag coefficient will determine how much you add.
I looked over my materials and it looks like a car with 'no' aft-body streamlining at all would be limited to a Cd minimum of 0.20.An extreme example would be the Blue Flame rocket powered land speed record car.It's rocket ship body has a higher drag than the blunt and 'stubby' Renault Vesta II.
It would basically be impossible to achieve lower drag without extending the rear.
The Following 5 Users Say Thank You to aerohead For This Useful Post:
California98Civic (01-04-2012), Cd (01-04-2012), drmiller100 (01-03-2012), KamperBob (01-03-2012), landsailor (01-04-2012)
Old 01-03-2012, 07:37 PM   #7 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Tundra 4WD xCab
Half Pint - '06 XT225
Half wake sounds pragmatic.
Kamper Bob, Recreation Engineer
Old 01-04-2012, 05:11 PM   #8 (permalink)
Schwinning!
Sven7's Avatar
The Anal Probe - '92 Probe GL
Team Ford
90 day: 35.92 mpg (US)
Wouldn't this work like a parachute, sucking energy from the car?
Here's how I see it. To inflate the sock it would have to have at least equal pressure inside than out. This would mean it's got to pull in a lot of air. So, to keep it from deflating or rippling at speed it might add more drag to your car than it actually solves. If you closed off the back and had small intakes at the cant rails like a Ford RS200's air intakes you might be able to keep it inflated. But I still doubt the real-world viability. Venturi intakes, perhaps?
Originally Posted by Weather Spotter View Post
Nothing fell off so that is good.
Old 01-04-2012, 08:23 PM   #9 (permalink)
I noticed today as the cold air made it where vehicle exhaust was visible, that the air behind certain vehicles is very violent. Awesome to see first hand that all this is true. Is there a template for the perfect boat tail design?
Old 01-04-2012, 10:53 PM   #10 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
Check this link for starters: Aerodynamic Streamlining Template: Part-C
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
