Old 07-07-2014, 10:18 PM   #1 (permalink)
boost gauge?
hey all,
i got a boost gauge for free….i was wondering if i could use it as a vacuum gauge?
Old 07-07-2014, 11:00 PM   #2 (permalink)
That depends, does it also measure vacuum?
Old 07-07-2014, 11:47 PM   #3 (permalink)
mbolton1990's Avatar
eco-crx - '90 honda crx hf
90 day: 56.89 mpg (US)
I was under the impression a boost gauge was just a vacuum gauge.
Old 07-08-2014, 12:39 AM   #4 (permalink)
davelobi's Avatar
CRX - '91 Honda CRX HF
Last 3: 63.1 mpg (US)
the ugly one - '97 saturn SL just sl,not sl1 or 2
Team Saturn
90 day: 44.15 mpg (US)
Vibe - '07 Pontiac Vibe
Team Pontiac
90 day: 44.24 mpg (US)
Hoopdie - '05 Toyota Corolla CE
90 day: 42.58 mpg (US)
boost vs vacuum is opposite in my mind. One measures suck one measures blow. Positive vs negative pressure.
Get bored very quickly. Vibe, Saturn, and crv all long gone. Been a while but I'm back in the game, gunna see what I can do with this Corolla.
Old 07-08-2014, 01:48 AM   #5 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
My boost gauge has both on the same dial. The left 1/3 of the face is vacuum the right 2/3rds is boost. It will function as one or the other but not both at the same time.
It is a Equus brand
Save gas
Old 07-08-2014, 06:20 AM   #6 (permalink)
its just a boost gauge not both, but a boost gauge hooks up to the waste gate? on the turbo? mine will be hooked up to an engine vacuum source i wonder if the gauge will read with opposite pressure? or will it be the same
Old 07-08-2014, 08:09 AM   #7 (permalink)
It won't work, since it is not capable of reading vacuum which is lower than atmospheric pressure, versus postive pressure which is boost.
regards
Mech
Old 07-08-2014, 08:23 AM   #8 (permalink)
ecomodded's Avatar
The boost gauge reads the turbo's positive psi pressure which moves the needle right.
A vacuum source on it would move the needle left / negative pressure.
Sounds like yours was not marked to go backwards - but it might , you never know until you try , despite being no scale to measure it with you could watch for peak vacuum or what ever. try it on a vacuum source or draw a breath threw it and see if the needle moves backwards.
Save gas
Old 07-08-2014, 08:49 AM   #9 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
We need a picture!
Old 07-08-2014, 10:50 AM   #10 (permalink)
I have a boost gauge (unsure of brand) on a Volvo 940 Turbo and you can definitely use it as a vacuum gauge.I stay out of boost 90% of the time I drive it and use it as a vacuum gauge,and it does a great job!The needle can show you negative pressure(vacuum) as well as positive (boost).
