Old 05-23-2009, 07:18 AM   #11 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by Ernie Rogers View Post
Could the difference of-- .009 /.00878 = 1.025-- 2.5% in Crr
be detected with a wheel tire tester? Maybe just barely. Any thoughts from the real world experts here?
Ernie Rogers
Just an anecdote from the trenches:
I know a major vehicle manufacturer refused to accept a tire modification proposed by a major tire manufacturer because the RR increased 3%. That tells me that not only is 3% detectable and reliable, but it also is detectable in the EPA Fuel Economy Test.
Old 05-23-2009, 09:12 AM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Thanks for clarifying.
"Tire rolling resistance varies inversely with tire pressure." It should be more valid toward higher pressures.
Darin actually did some coastdown testing based on psi, found the returns diminished sharply at a bout 45psi in his particular case:
Experiment: coast down distances (rolling resistance) @ various tire pressures
"0.9%"
Yah, that is tough to discern on the street, even with accurate fuel consumption feedback.
Old 05-24-2009, 10:07 PM   #13 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
If I had no other test or data available, I'd put a lot of faith in how long a tire would bounce, given as many constant factors as I could arrange.
Old 05-25-2009, 03:01 AM   #14 (permalink)
Ernie Rogers
Darin had two sets of data at his web site. I graphed the numbers for the first case (the Metro), then curve-fit them by eye and studied the results.
It appears from his description that the tests may have had a tail wind close to equalling the average speed in this coast-down test. If so, the aero drag is close to zero and only rolling resistance stopped the car. For the case of no wind, the rolling resistance coefficient is equal to the average slope of the road. Here are the Crr numbers I got for pressures from 20 psi to 55 psi--
20............0.0147
25............0.0131
30............0.0121
35............0.0114
40............0.0108
45............0.0104
50............0.0101
55............0.0099
These Crr values very closely fit the following formula--
Crr = .0071 + 0.15 /P
Ohh, my! Maybe I had the wind in the wrong direction. I can do that calculation but maybe someone else would like a turn.
Ernie Rogers
"0.9%"
Old 05-25-2009, 07:38 PM   #15 (permalink)
Ernie Rogers
Recalculated Crr for head wind
The last time, I analyzed Darin's coast-down data on the assumption that he described a tailwind. The results suggested too much friction in the drive train, and I assumed the cause was a misunderstanding on the wind direction. I repeated the calculation assuming a headwind instead.
With a headwind that adds to aero drag, it became necessary to include a drag term in the analysis, and that imposed guessing some parameters about the car. Here are the ones I used--
Frontal area = 19.5 sq.ft.
Cd = 0.32
Car weight = 2,000 lb
I used a "constant" headwind, the RMS of wind speed (6 mph at 22.5 deg = 5.5 mph) and the reported max air speed (11.5 mph + 5.5 mph) = 12.6 mph RMS. Here are the results, Crr versus tire pressure--
P___________Crr_
20............0.01348 (extra digits are carried for fitting to formula)
25............0.01188
30............0.01086
35............0.01015
40............0.00957
45............0.00919
50............0.00889
55............0.00863
Crr = .0059 + 0.15 /P
It's amazing to me that only the constant term changed in considering a head wind instead of a tail wind. I don't know the physical significance of the constant term, except that it does incorporate friction of drive train components which would not change with tire pressure.
If one guesses that the constant term is due entirely to actions outside the tire, then you get an eye-popping Crr for the tire only of 0.0033 at 45 psi.
Note to the casual observer: A coast-down test doesn't produce significant heat in the tire (I think) so low-pressure results can be somewhat higher (because the tire is cooler) than in a measurement at normal tire speed.
Ernie Rogers
Ernie Rogers
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
Online tool: shows aerodynamic drag, rolling resistance, power required & est. MPG MetroMPG Aerodynamics 57 09-28-2011 06:41 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 09:45 PM
Calculating Rolling Resistance SVOboy EcoModding Central 0 11-18-2007 04:20 AM
