Their site is pretty bad, as a starting point avoid the clusters of what look like normal LED's, they are dim and worthless, I have a box full of them and would never put them back in a vehicle.
The 3 watt LED"s that I have in my car are really bright, brighter then the stock bulbs but they look to be replacing them with the cluster type that have the square chips with a clear or yellow dot in the center, I have a home LED bulb replacement that has that style of LED and it's blindingly bright, their specs also seem to give a higher lumin output per watt for that square chip style LED, twice the price but 3 times the light output?
