Old 08-03-2011, 09:54 PM   #1 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
Break light fuse blowing instantly
I have a 1997 Civic, the break lights were not working so I checked the fuse first. The car calls for a 15A fuse and had a burnt 20A fuse in it. I replaced the fuse but only had another 20A and not a 15A so I went ahead and put that 20A in, I hit the breaks, it turned on for a millisecond and the fuse blew... Any ideas whats going on?
Old 08-03-2011, 11:31 PM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
They're aptly named "break lights".
Gasoline Fumes (08-04-2011)
Old 08-03-2011, 11:32 PM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
The circuit is shorting to ground. Trace it looking for an exposed bare wire, pinched wiring, or a frayed wire.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
The Following User Says Thank You to SentraSE-R For This Useful Post:
RandomFact314 (08-10-2011)
Old 08-04-2011, 08:23 AM   #4 (permalink)
You can also test it first with no bulbs in any sockets, then add each one and test it might help narrow down area that is shorted .
The Following User Says Thank You to EdKiefer For This Useful Post:
Old 08-04-2011, 03:51 PM   #5 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
You may have a break in the brake lights?
It could be a water leak or corrosion causing a short, maybe?
Old 08-10-2011, 03:36 AM   #6 (permalink)
The CRUSHINATOR - '97 E250 cargo van
90 day: 11.71 mpg (US)
I would start by checking the bulbs/sockets first. I have seen too many cars with incorrect/broken bulbs. I have also seen lots with corrosion. Then I would check for any aftermarket alarms, amps, subs and where they tied in to the vehicle wiring.
You can always put a paperclip in where the fuse goes and do a "smoke test." Just kidding!
Smart Fortwo: MPG: 33 city 41 hwy HP: 70 seats: 2
My 1989 Civic: MPG: 35 city 41 hwy HP: 160 seats: 5
not so smart are we now?
The Following User Says Thank You to Hatchtastic For This Useful Post:
Old 08-10-2011, 04:26 PM   #7 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
Could also be a shorted out brake light switch, but more likely a poor connection or bare wire somewhere in the brake system.
The Following User Says Thank You to Ford Man For This Useful Post:
Old 08-11-2011, 12:28 PM   #8 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
First I would check the wires from the sockets as far back to the battery as you can and check from the fuse to out, also look under the dash and check from the break switch back. After that I would remove all bulbs replace the fuse and press the break check the fuse, then reinstall one light checking the socket for an obstruction and the bulb to make sure one of the contact wires is not crossing over shorting it out. From there keep adding one light at a time till it blows.
When it blows remove the last light you tried and add the next light leaving the one it blew on out and see if it happens again. If it blew on the last light (all installed) remove one or the previous lights and use it in the last socket (the one that blew it). If it blows the fuse this time you have located the one that is grounded out and you will need to check that socket and wiring from end to start.
If it only blows with all installed it is a draw problem and could be a PIA to find or could have some corrosion on/in the wires could have happened if there was a leak in the trunk at one time and it has wicked down the wire or could be on the engine/fuse box side with the same issue.
I move at the speed of awesome.
Old 08-15-2011, 07:30 PM   #9 (permalink)
The Neon - '00 Neon
House of Tudor
OK so I went out and bought another 4 fuses the other day so I can try to figure this problem out.
Try 1: Went outside and pulled out the brake bulbs and put a new fuse in, it blew instantly.
Try 2: I started looking around for noticeably odd wiring, and thought "Well if I can just get my 3ed brake light to work then It will atleast be more safe" so I looked at it and noticed it was unplugged and the wires that plugged into it was plugged into something else so I unplugged that and put a new fuse in.
Turned on the lights and the tails DO light up now! woot!
Now I just gotta go buy some bulbs because out of the 2 in the car and the extra 2 I had in the house, only 1 worked. I had another one that just did the low beam but not the high (for when you touch the breaks)
BTW: Horn works now too! yay
Old 08-15-2011, 10:41 PM   #10 (permalink)
Pishtaco
SentraSE-R's Avatar
Good detective work. Congratz.
Darrell
blowing, civic, fuse, honda, instantly
