Old 03-22-2016, 05:05 PM   #21 (permalink)
C5 Galaxy
Originally Posted by Hog Dr View Post
I realize I'm dredging up an old post, but I only discovered this trailer today, and came straight here to perform a search.
As it pertains to the rounded tail, I wonder what it would take to make a tail section that lifts like the nose of a C5 Galaxy. Could a clever contraption of torsion springs and hydraulic dampers could do the heavy lifting? Perhaps the dead space inside the cone could be used to store Race Ramps or similar product to load vehicles/cargo. Maybe a cargo net, suspended from inside the cone, could be used to secure small items. I think a mildewed, old Airstream could make a likely prototype candidate.
I've seen nosecones on trailers at the Pate Swap Meet with multiple hinge articulations which allow the cone to clear the trailer box,then swing up.I may have photos,but not sure.
A problem with this design is that if you get a wind gust out of the wrong direction you've got a parachute that is going to test the integrity of it's mount.
It can also act as a spinnaker sail on a sailboat,capable of moving an un-hitched trailer.
Old 03-22-2016, 05:18 PM   #22 (permalink)
I posted about a trailer that may interest you a while back. You may not have found it searching as it was buried in another thread.
Boattailed car trailer
The Following User Says Thank You to ennored For This Useful Post:
aerohead (03-22-2016)
Old 03-24-2016, 03:44 AM   #23 (permalink)
Sure, why not. But you're fighting gravity.
Take the same contraption. split in halves and turn it 90°. You find you need the length added on each side with the single hinge. Convert to a Watts four-bar linkage. Now you only need to accommodate the curvature, not the length of the tail.
Last edited by freebeard; 03-24-2016 at 03:47 AM.. Reason: 'the length' for 'half the width'
MetroMPG.com: Electric pusher trailer MetroMPG Fossil Fuel Free 30 04-23-2015 03:24 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 07:18 AM
Areomodding my 6x12 enclosed trailer Chris D. Aerodynamics 56 11-16-2008 09:58 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
Cap vs Trailer: Trailer wins! bennelson Aerodynamics 10 05-08-2008 10:08 AM
