Old 12-09-2013, 01:00 AM   #11 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Also found a neat link from mobile1 for a oil recommendation according to vehicle
What's the right oil for my car?
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 12-09-2013, 06:48 AM   #12 (permalink)
Joggernot's Avatar
I've run 0-20W or 0-30W synthetic oil in NM and TX for the past 10 years in the Honda Accord. Still doesn't burn any oil between changes. My next car will run 5000 miles on what they recommend, and then change over to these oils. I changed the Tacoma over to 0-30W when I bought it used. No problems with it either. all oil is synthetic: either Mobile 1 or O'Reilly's.
On a side note...when I bought the Accord I tried the 10,000 miles between oil changes and the oil came out in clumps. Dropped back to my normal 3K to 5K and have had no trouble. The car runs very well.
Old 12-09-2013, 09:10 AM   #13 (permalink)
Camry - '99 Toyota Camry
90 day: 39.84 mpg (US)
Just my last 2 oil changes with this car I've used it before in my wife's car.
99 Camry
Old 12-09-2013, 09:50 AM   #14 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
It's only thinner on super cold starts; where the oil is too thick to lubricate any way. Running down the highway, with the oil completely up to temperature (which is different than coolant temperature) , there should be no difference in thickness.
Unless the 0w-30 is missing something that your engine needs (M1 0w-30 is light on ZDDP), it's going to work great for your engine.
Cost is up there, though.
Old 12-09-2013, 12:01 PM   #15 (permalink)
I only change my wife's. Every 10k but I use the 15k mobile 1
99 Camry
Old 12-09-2013, 02:06 PM   #16 (permalink)
You should be good for at least 15-20K miles on that.
A lot of people on bob is the oil guy go at least 10K miles on "regular" Mobil1 and Mobil1 AFE and used oil analysis data says they are good for much more than 10K miles.
If I were using EP, I would run to 10K miles then do a UOA (used oil analysis), get data and extend as long as safe.
Old 12-09-2013, 02:31 PM   #17 (permalink)
I just run mine 5k so my mpg doesn't hurt too bad
99 Camry
Old 12-10-2013, 08:51 PM   #18 (permalink)
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
i once switched from 5w-40 shell rotella to 0w-30 german castrol and saw no difference in fuel economy.
