Old 12-18-2008, 02:22 PM   #91 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Yes.
Old 12-18-2008, 02:25 PM   #92 (permalink)
Not wearing pants
Thanks.
Old 12-18-2008, 03:03 PM   #93 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
pasadena_commut -
Originally Posted by pasadena_commut View Post
NM = Newton meters. Torque units are force X distance.
Thank you for the correction. It didn't look right, but I didn't know what else it might be.
CarloSW2
American Solar Energy Society
Old 12-19-2008, 09:15 PM   #94 (permalink)
Pokémoderator
cfg83's Avatar
Hello -
Here is the max(?) torque rating for my engine :
What are the units of this? Are they also Newton-meters (Nm)?
EDIT: Answering my own question :
HowStuffWorks "How do you convert engine torque to horsepower?"
Have you ever looked at the specs of an engine in a magazine and seen something like "this engine makes 300 pound-feet of torque at 4,000 RPM," and wondered how much power that was? How much horsepower are we talking about here? You can calculate how many foot-pounds of horsepower this engine produces using a common equation: ...
From this, I can go here to convert to Nm :
Torque Conversion
122 lb-ft => 165.41004 Nm
This makes me happy because this agrees with my BSFC chart.
Thanks,
CarloSW2
Old 01-05-2009, 02:30 AM   #95 (permalink)
Pokémoderator
cfg83's Avatar
Hello -
Based on this assumption :
Torque Conversion
I made this table to correlate Torque and the OBDII "LOD" (engine load) parameter :
Question: Does the above look correct?
If the answer is yes, then I have the ability to predict fuel consumption based on OBDII LOD and RPM parameters.
CarloSW2
Old 01-05-2009, 10:39 AM   #96 (permalink)
CM400E - '81 CM400E
Looks right to me.
Old 01-05-2009, 11:02 AM   #97 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Are you sure the LOD value corresponds to absolute peak theoretical torque output? Or does it mean maximum torque output for a given engine speed? EG: if you floor the gas and hold it there in top gear at 1000 RPM, does it not read LOD=100, and continue to read LOD=100 while the RPM climbs?
EDIT: from the SGII user manual
LOD = This is a percentage of the maximum power available currently being generated. In some vehicles it is the maximum available at the present RPM.
Seems to be an "it depends" situation.
Old 01-05-2009, 12:29 PM   #98 (permalink)
Pokémoderator
cfg83's Avatar
MetroMPG -
I can work with that because I have the "torque curve" at the top of the chart.
The "it depends" sounds like a saturnfans question.
CarloSW2
Old 01-05-2009, 06:34 PM   #99 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
If you slap down the throttle at low rpm and LOD goes to ~100, it's based on peak torque. If it increases w/ rpm at WOT, it's based on peak power. If it's based on torque, as long as you have LOD, RPM, and vehicle speed, you can predict fuel consumption.
Old 01-06-2009, 03:21 AM   #100 (permalink)
I am curious about how bsfc maps are produced. Could anyone point me to literature on the subject?
Also, is it correct that with fuel injection the mixture (except for warming up/choke) is always stoichiometric (in correct amounts for full combustion)? If so, then is it solely the amount of fuel/air mixture that is in the cylinder that determines the power output, and this amount is lineally dependent upon pressure in the inlet manifold, and this pressure is lineally related to the throttle position?
Thanks in advance.
