The BSFC chart thread (post 'em if you got 'em)
Had a suggestion to post BSFC charts for various vehicles in one place. If you've got one, post it in this thread. I'll add an index in this first post if it gets long.
Geo/Suzuki 1.0L SI engine Thanks to tasdrouille who posted a link to a fuzzy - and the only - bsfc chart I've yet seen for the Suzuki/Geo 1.0L, non-XFi engine (judging by power rating): The original, fuzzy image: Cleaned up image. Note: I "best guessed" a few digits: http://ecomodder.com/imgs/geo-1L-bsf...nstruction.gif Note that peak torque for this engine is listed as: Torque(lb/ft) @ RPM: 58 @ 3,300 (Non-XFi Models, XFi not listed - source) And 58 lb/ft = 78.6 Nm (calculator) |
Ok.
What I'm getting: Driving at WOT from about 2600 to 3600 rpm will yeild the minimum fuel used for power produced. What I'm wondern: Why is there so much data on the graph? Like islands instead of just a line, theres seems to be 8-10 points plotted for every rpm from 1100 to 5000. |
Wait a sec... the aliens were just communicating with my brain... Each line is just fuel consumption for a given torque and rpm, throttle position is not represented on this graph. I think.
1 Attachment(s)
Hello -
Here's one for my Saturn 1.9 liter DOHC engine : http://forum.ecomodder.com/attachmen...9&d=1205914740 Attachment 469 I got it from here : Fuzzy Pareto Frontiers in Multidisciplinary System Architecture Analysis http://web.mit.edu/deweck/www/PDF_ar...-2004-4553.pdf CarloSW2 |
Here's one illustrating NA vs Turbocharged for a given engine. It clearly shows how a turbocharger can lead to better FE as you can downsize the engine and get the same power output, but you extend the bsfc sweet spot to lower loads vs the bigger engine.
http://www.tc.gc.ca/programs/environ...e/Final_30.gif |
Here is a chart for a 2001 GM vortech 4.3l v-6. It shows both, the truck and marine applications.
Brake Specific Fuel Consumption The engine brake specific fuel consumption (bsfc) shall be as follows: 1. The engines nominal brake specific fuel consumption point on a W.O.T. curve is shown in table 6.3 -I. 2. The engine nominal specific fuel consumption shown in table 7.3 -I are for an operating range between peak torque and maximum power at full load. 3. The engines best part throttle bsfc (on a fuel map) is shown in table 7.3 -I. Table 6.3 L35 V6 4.3L Engine BSFC rpm truck marine units 800 0.529 0.495 lb./BHP-Hr 1200 0.521 0.478 lb./BHP-Hr 1600 0.484 0.481 lb./BHP-Hr 2000 0.470 0.471 lb./BHP-Hr 2400 0.471 0.466 lb./BHP-Hr 2800 0.469 0.472 lb./BHP-Hr 3200 0.478 0.458 lb./BHP-Hr 3600 0.483 0.452 lb./BHP-Hr 4000 0.500 0.460 lb./BHP-Hr 4400 0.525 0.479 lb./BHP-Hr 4800 0.532 0.506 lb./BHP-Hr 5200 0.556 0.550 lb./BHP-Hr |
MetroMPG -
CarloSW2 |
I always thought it was simply the torque curve at WOT through the whole range. I could be mistaken though.
I agree that those look like torque curves...
So this is a load vs speed graph that maps fuel/power gradients :D ...the way I'm reading them is that the sweet spot for acceleration is about 1/2 to 2/3 throttle (y-axis...load really) at 1500-3500 rpm, depending on what your torque curve looks like. |
