BSFC map. What am I looking at?
Just as an example, here a legible BSFC map. What is the scale of the Iso lines and how can they be shown as higher than the torque curve? Do any of the lines necessarily show 100% throttle? I am assuming the 250 line is centered around 95% throttle lets say, and the 275 line is the constant fuel consumption Iso with 100% throttle across the top which happens to blend to the same consumption with lesser torque output and a lesser throttle opening of 85% (or something) around it's lower portion.
. . http://sphotos-a.xx.fbcdn.net/hphoto...12189371_n.jpg . . |
By scale do you mean 275 whats? - the top of the chart says "BSFC (gr.kW.hr)" that is grams of fuel needed to produce a kilowatt hour of work. The maximum torque at 3500 rpm is about 158 Nm but the specific fuel consumption is about 270 gr/kw hr. This is how you show that if you only have iso lines at multiples of 25. Do any of the lines necessarily show 100% throttle? No. I am assuming the 250 line is centered around 95% throttle lets say, and the 275 line is the constant fuel consumption Iso with 100% throttle across the top which happens to blend to the same consumption with lesser torque output and a lesser throttle opening of 85% (or something) around it's lower portion. Kinda like that, the iso lines are not throttle positions. Only in the most general way can you say that the part of an iso line near full output is near full throttle - but otherwise the graph give no information about throttle. -mort |
. X and Y of the bold torque curve are clearly labeled but all of the BSFC maps I have seen never label the Y axis of the iso lines. Unless this graph is just an oddball. |
Are you sure that's the torqure curve? AFAIK, most cars don't have two torque peaks.
Stays kind of high toward redline to be torque doesn't it. Maybe I should just pick a different graph.
Yes, the vertical axis for the fuel consumption iso lines is also torque. In this case Nm = Newton meters. That's fairly common, but you will also see ft lbs. Both are measured at the flywheel. But many graphs show cylinder pressure, BMEP = brake mean effective pressure, in bars or rarely psi. That is convertible to torque. As I said, the iso lines seem to go above the maximum torque, simply to show what the fuel consumption was on the maximum torque line. It isn't as if the engine could get to that iso line. It's handy to know that at maximum torque at, say 3500 rpm, the fuel consumption is hardly better than 275. But it would be useful different information if that 275 iso line zoomed off showing that at 3500 rpm the fuel consumption was almost 250. Put it another way, showing an iso line outside the engine operating area allows you to determine the bsfc at points where the engine does operate. -mort |
VWVortex.com - Driving for Fuel Efficiency (MPG, mileage, miles per gallon) - Guide and Discussion, especially TDI
