Old 09-24-2008, 11:00 PM   #21 (permalink)
stinky - '97 metro lsi
90 day: 44.71 mpg (US)
Originally Posted by Johnny Mullet View Post
A 1995-1997 Metro 3 door hatchback
Install an XFi cam
Install a 1995+ swift 1.3L manual 5 speed
P155/80R13 wheel/tire combo
Install a tach cluster.
High flow universal cat with 2" pipe to a center mounted cherry bomb and a new stock muffler.
For the best FE I would say a straight pipe back to the back, then you could use for the last foot or two go down in diameter. with a little testing by swapping different size diameters one could discover the best size. I have no idea how one or even two mufflers will help FE. Also alot of people say look at coyotex's car. wouldnt that convertable be closer to a sedan and not a hatchback.
Old 09-24-2008, 11:29 PM   #22 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
I just went to a 2" diameter pipe basically straight back to a muffler. It seems to be the best overall. I had a 1.25" straight pipe and the car really sucked with it on there. I think a small tip might help out some but not overly small or long. The factory cars had a pipe that looked around 2" diameter but had a tiny little tip on the muffler. I figure they had to have some reason to do that so I will probably made a slip in reducer to cut the size of the opening down on my replacement muffler's 2" tip.
I don't think a convertible is ideal for FE(prob the worst) but with the top up it seems to do pretty well. I will eventually get some coastdown testing done with it and figure out the actual numbers. I am not sure what one is better shape wise though sedan or hatchback. I would guess sedan but I am not really sure if anyone has actual numbers to compare them.
My Convertible Metro XFI Plug in Hybrid Project build log
Old 09-25-2008, 07:59 AM   #23 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Originally Posted by williamgeorge View Post
By themselves, police should not be the sole blame for spikes in crime nor should they take sole credit for drops in crime rates. However, whenever crime goes up the police detractors multiply faster than those who praise cops when crime drops.
williamgeorge
Spambot
Old 09-25-2008, 02:23 PM   #24 (permalink)
guitarterry, I am trying to understand what you want, and what you are willing to do to get there.
I followed coyotex's 'vert build from beginning to end, it's far from a custom built stock car.
Don't confuse the complete chassis rebuild (to repair the rotten unibody) with the very inovative ecomods he has also done.
There's lots and lots of gold nuggets to be mined from that story, you just need to read the entire blog and use what will apply to your 2nd gen sedan. if you read the entire thing and still don't see the relavence to your needs, I'll eat my keyboard.
Old 09-25-2008, 09:35 PM   #25 (permalink)
I like coyote's build alot, But I was wanting to go to u wreck it (junk yard) and get the best stuff as im doing it.
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 11:00 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 08:26 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 05:05 PM
