Old 09-20-2008, 03:00 PM   #1 (permalink)
stinky - '97 metro lsi
90 day: 44.71 mpg (US)
Build the best metro
I would swear somebody has did this but i was wonder what the best package would be if you had all the parts available.
1. Body- The sedan would be the best cause it has the lowest cd? Once u striped the weight down wouldnt cd be the most important.
Metro hatchback vs sedan
2. Motor- 3 cylinder
3. Tranny- the 95+ 1.3
4. Tires- I believe the 12's (145/82/12) would be best if you could get the right gearing in the tranny but otherwise the 13's are (155/80/13)
5. Muffler. None-Run a straight pipe after the cat. restrict the end to tune the backpressure.
6. 93-94 flat front bumper, not rounded one
Old 09-20-2008, 10:06 PM   #2 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
if you are going to go with a sedan why not just cut off the passenger side and make it an inline two passenger, taking a 4 door and making it a two door with the two doors on the drivers side.
I would think that a xfi engine and tranny would be the way to go, 135 R13 tires would be what I would use, and if less restriction on an exhaust is the way to go then just do away with it all together... wait I've done that before on a motorcycle and it had no power with out the the exhaust system to keep the exhaust velocity up, you can test it with any engine.
Old 09-20-2008, 10:45 PM   #3 (permalink)
Yaris What????
Yaristock's Avatar
Yari - '07 Yaris Liftback
Weren't you the guy who said the I4 was more economical than an I3. Have a change of heart? Those little things barely make any power, a straight pipe would strip what little you have on the low end, and couple reduce backpressure so drastically that the engine would probably stall right after starting. On the right track thought.
Yaris Liftback + 3 Adults + Toddler + Luggage/Crap = 40mpg@80mph
It just came to me about blogging lol. Its like an orgasm a few good shots and the rest is dribbles lol!
Old 09-20-2008, 11:01 PM   #4 (permalink)
if you are going to chop the car up it doesnt matter what body u start with
Old 09-20-2008, 11:23 PM   #5 (permalink)
I'll have what you are smoking. I asked the question why the I4 turning at 2400rpm wouldnt be more economical than the I3 turning at 3200rpm ,especially since i travel alot of miles at a time.
The reasons were;
1. the frictional losses would be lower in the I4 because since there is the same amout of cylinders firing per minute. the I4 is turning slower and friction increase as a square of speed.
2. the accesories are turning slower in the I4, just like if you used an underdrive pulley.
3. The motor should last 25% longer
But i never did get a real answer, people kept talking about idling and how many injectors were firing. hell one guy even talked about how those old out-of-date bulky, performance v8's were less economical than a little motor.
Old 09-20-2008, 11:53 PM   #6 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
How do you find 135 R13 tires and suitable wheels? I've gone the route of looking for available LRR tires that help tweak the gear ratio, but the wheels are scarce, too.
The 8-valve and the XFI had the tallest transmission gears. The pre-'95 models are lighter and smaller, and of those, the coupe is 45 pounds lighter than the 4-door, and shaped to make it easy to extend the tail.
I think that the performance advantage of an exhaust pipe comes not from back pressure, but from suction produced by the momentum of the exhaust gasses in a tuned pipe.
Old 09-21-2008, 12:18 AM   #7 (permalink)
I am running 165/80/13's on my 1.3 auto lsi 4dt. getting 44. as i drive 50 miles to work one way, the cd matter more than weight. and weight is easier for me the fix than body style. (i dont do anything weight wise right now on my car). On the muffler thats why i think its best to run a pipe all the way back. You can then tune it by changing the size. But you dont need a muffler on these engines.
Old 09-21-2008, 01:57 AM   #8 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
Last 3: 58.02 mpg (US)
put a honda engine in it
muahahaha
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 09-21-2008, 12:58 PM   #9 (permalink)
I know the chevy metro is really am import, but i cant sink low enough to completly turn my back on america and go with honda. But i guess if nobody pops the hood just my conscience will be hurt.
Old 09-21-2008, 03:54 PM   #10 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
CoyoteX already built the ultimate Metro.
Geo Metro XFI Convertible Project Finished
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 11:00 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 08:26 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 05:05 PM
