Old 08-12-2010, 01:31 PM   #151 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Originally Posted by Creeper View Post
I was contemplating a VW TDI engine, Smartfor Two, or Fiat 500 Turbo 2cylender one.
Forget the Fiat 2 cylinder, in road tests it's using far more fuel than its official rating in the 500 - even when driven sensibly.
If you really want to go ahead with this, start from a Smart - it's already got the rear mounting, rearwheel drive set-up.
A local bike mag started building a diesel bike based on a Smart diesel (0.8 L).
Dunno what became of it though.
Lifetime fuel consumption :
Old 08-12-2010, 03:34 PM   #152 (permalink)
Kool, my only concern will be getting air to the intercooler I can work that out in the body design. CDI engines are starting to come down in price overhere. There are plent to choose from in Canada.
2 cars one never gets driven the other is an MPG project already at 5% increase in standard driving economy CAI and Pulstar plus. Thinking weight reduction next year.
Old 08-13-2010, 03:37 AM   #153 (permalink)
euromodder's Avatar
Diesel
Forgot to add ...
The bike mag and the tech school they worked with, had some serious issues with changing the drive configuration to a mid-mounted engine in the bike, driving a chain (or belt ?).
So keeping close to the original drivetrain configuration should pay off - there'll be enough other troubles
They also bought a whole car that had been in a collision so they had all the accessories to go with it.
From the pics they took, the Smart engine & drive train package is rather compact. Being a tiny displacement engine, its air and cooling requirements aren't that big either.
Smartd diesels have also been made to run on veggie oil
http://www.dieselveg.com/smart.htm
Old 08-16-2010, 08:30 PM   #154 (permalink)
woodsmith's Avatar
If I had to use an ICE I would use a small diesel front drive unit in a reverse trike or a mid engine to a motorbike rear end depending on if I want to bother with a passenger seat or two.
With a single seater I would be tempted to use the fuselage from a glider if I could find one.
But apart from the little detail of an ICE here is what I am building in my basement workshop.
I am scratch building a single seat reverse trike but electric. The aim is to keep below 350kg plus driver and batteries.
I want to use it for my 30 mile each way commute where I am on my own with just a soft bag or two.
I have a thread here: I want to build a trike! - DIY Electric Car Forums
The initial design idea was front motor rear drive like this:
It developed a bit to this:
The front wheels are too small, they are just stand ins.
Now I have a BMW K100 rear end I have moved the motor to the mid position. It gives luggage space and allows a Kammback to develop from the back of the cockpit. I will be keeping the big fat rear tyre from the earlier photos and fitting it to an MGA 15" wire wheel with centre lock nut adaptd to teh K100 final drive.
Taking a leaf out the Blastolene cars, the Boss Hogg and the Napier Railton I am using a 12" motor!
The motor isn't just for the sake of it, or because I can (ok, it is) but it is also such a big lazy easy spinning motor that brings the CoG very low down.
Using my 9" motor in the same place means that my personal CoG has a bigger effect higher up in such a light vehicle. (Does that justify it?)
Anyway, for the benefit of this thread it is a bit of 'putting my money where my mouth is' as I do keep saying that an electric single seat reverse trike is the best solution for me.
I just hope I can afford to finish it.
My EV Trike Project
Old 10-04-2010, 05:03 PM   #155 (permalink)
EcoModder Newbie
GTA - '87 GTA
2k6 Silverado - '06 Silverado LS
Send a message via ICQ to PhilA Send a message via Yahoo to PhilA
If I were building something on a budget to satisfy this, I think it'd probably have a Honda ED-series engine putting power through a freewheeling preselector gearbox into a shaft-drive single rear wheel (BMW motorbike style).
Tadpole design, narrow front (think Morgan 3-wheeler style) with ducted cooling up the back. Bulkhead-mounted fuel tank, polycarbonate fairing. Front suspension single wishbone/tilted strut, which can be faired. Kamm rear end.
All off-the shelf, conventional stuff, probably an excess of power available but it'd keep up with traffic, is simple enough that it can shut down when it's not needed and fire up when it is. Low unsprung weight for higher speed handling.
--Phil
Old 10-04-2010, 05:47 PM   #156 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
This is fairly close
How To Build Your Own Dream Car On A Budget
Replace Busa motor with PD 150 (the bad boy of 4 cylinder VW TDI) with a tune (makes about 200 whp), adjust the roll bar, run muck longer control arms up front, add bio-diesel, and I'd be near perfect.
6 speed ALH TDI
Old 10-21-2010, 02:24 AM   #157 (permalink)
starly - '82 starlet DL
90 day: 40.77 mpg (US)
personally i would use my car as a base or an earlier ke10 corolla (these were pretty much teardropped designed)
a few aerodynamic mods, possible fuel injection upgrade, or at least a better carb, alluminium chassis instead of steel, lower it but not to much, few mods to the engine and she'd be right... easy 60mpg
these things way next to nothing and boy do the accelerate quickly with a few mods, they have a high frontal area, but nothing some custom panel beating cant fix
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 23 11-21-2010 03:32 PM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
