Old 05-19-2016, 07:13 PM   #1 (permalink)
Camry - '99 Toyota Camry
90 day: 39.84 mpg (US)
bumper help
I'm replacing my damaged bumper on my 99 Camry and I'm debating on going with an aftermarket one as they are typically taller and will be closer to the grouf as opposed to the OEM height. Some of the ones I'm looking at have more open area tho. Any thoughts/suggestions would be much appreciated.
99 Camry
Old 05-19-2016, 07:49 PM   #2 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Anything you can do to make your bumper as vertical as possible and push as much air as possible around the sides, as opposed to over the top or under the car will help you out.
I like this if you block out the huge hole in the front as much as possible making the cooling hole as low and close to the center as possible.
The only real air inlet on this car is the one below "Camry" and half of it is taped shut when it's go time.
The Following User Says Thank You to ChazInMT For This Useful Post:
sully06 (05-19-2016)
Old 05-19-2016, 10:22 PM   #3 (permalink)
That's actually the one I was thinking about going with. On my oem bumper I typically block out the entire bottom and just leave the top open for cooling.
99 Camry
Old 05-19-2016, 10:58 PM   #4 (permalink)
Zip ties are also popular.
MobilOne (05-21-2016), sully06 (05-19-2016)
Old 05-20-2016, 04:17 PM   #5 (permalink)
http://www.motifake.com/necessary-tools-shelby-cobra-duct-tape-zoomer-demotivational-posters-164710.html
Old 05-20-2016, 05:40 PM   #6 (permalink)
bumper
A single,size-optimized and ducted opening at the forward stagnation point is preferred.
Ground clearance is a big issue.Here are the recommendations which will allow the car to stay in one piece
sully06 (05-24-2016)
Old 05-21-2016, 02:12 AM   #7 (permalink)
The 'back 40 is fenced and cross-fenced. Optimized for lefts?
aerohead is too modest to toot his own horn:
https://strollingamok.wordpress.com/2014/09/30/taking-cheapskate-seriously/
Bonus points for it being round. That's a nice write-up.
The sense of accomplishment must be strong, I imagine, but is there such a thing as tedious excitement?
aerohead (05-21-2016), sully06 (05-24-2016)
Old 05-24-2016, 12:38 PM   #8 (permalink)
The factory ride height is quite high on that body style Camry. I'm also lowering the car 2 inches so with that and the aftermarket bumper I should be close go the ground but not too close
99 Camry
Old 05-24-2016, 01:02 PM   #9 (permalink)
http://amazon.com
Let it grind.
