Old 12-03-2010, 01:34 AM   #1 (permalink)
Lone Ranger - '97 Ranger Splash
90 day: 28 mpg (US)
A/C delete question
I am looking at changing the serpentine belt on my Ranger and not using the A/C compressor. This is an easy change as the belt routing allows for this. My question is should I disconnect the wiring to the compressor. If I don't will it damage the compressor if I turn the cooling selector past the A/C setting momentarily? Also, doesn't the compressor run when you use the defroster? I know that trucks without A/C have defrosters but it seems like I can hear mine engage when I defrost my windshield. Is there really a significant drag on the engine from the belt going around the compressor and not being used?
Thanks
Old 12-03-2010, 01:50 AM   #2 (permalink)
Lil Sulf - '94 Corolla
90 day: 47.62 mpg (US)
I want to get rid of my a/c components but I need them to defog the windshield sometimes. There is parasitic drag on the engine from having the belt on there but it's not significant at all (I think)- you probably will never tell the difference.
And that's without a Scangauge o.O
Old 12-03-2010, 01:11 PM   #3 (permalink)
Yes, you should remove the electrical connector from the compressor if you plan on doing this modification, although it won't make much difference. Simply disconnect that wiring plug and secure the wire with a zip tie.
Most vehicles do engage the compressor on the defrost setting, but you don't necessarily have to do so. Simply blowing fresh air onto the windshield is somewhat effective, and adding heat to the air makes it even more effective.
How to use your A/C more efficiently gascort Hypermiling / EcoDriver's Ed 21 02-18-2010 10:21 PM
Plan is to remove the A/C of my '02 Corolla Kincurd EcoModding Central 10 01-13-2010 09:57 PM
A/C compressor delete? Casey EcoModding Central 9 11-13-2009 04:32 PM
yearly question: 12v a/c bgd73 Off-Topic Tech 5 07-18-2009 02:51 AM
Seats delete & MoT question Eddles EcoModding Central 6 06-30-2009 05:06 PM
