Old 08-04-2009, 11:52 AM   #41 (permalink)
Ol' Skooler
Trailer Queen - '67 Mustang
90 day: 16.08 mpg (US)
Nightie - '09 XL1200N Nightster
90 day: 32.92 mpg (US)
Nightie + Mustang - '67 Combined FE index
90 day: 15.33 mpg (US)
Originally Posted by cfg83 View Post
elhigh -
I might try that (on the way home). If I don't pass out, I may get better acclimated to the inland LA summers.
CarloSW2
Yeah, when I moved here from California back in '05, the summers here clubbed me over the head. Not having a/c has really allowed me to acclimate to the summers a lot better even than most natives here...and I sometimes have to run the heat to vent a little excess from my motor when it hits 220*. It's a great little side bonus I hadn't bargained on.
'67 Mustang - Real cars aren't made out of plastic and computers.
'09 Harley Nightster
Old 08-04-2009, 12:31 PM   #42 (permalink)
civic - '08 civic lx
90 day: 34.92 mpg (US)
if it's so hot i need(want) to run A/C, i turn it on when i'm coasting down hills, and turn it off when climbing. level ground i cycle as needed to keep from having a heat stroke.
Old 08-04-2009, 01:15 PM   #43 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
My Geo doesn't have A/C, and the fan doesn't work. My truck I use A/C because I can't get over 20mpg with it no matter what I do.
Old 08-04-2009, 09:08 PM   #44 (permalink)
Certified Duct Tape Tech.
swoody's Avatar
Slow Ride - '00 Civic DX
90 day: 46.32 mpg (US)
I'm with you Madison. My Civic has no air, so I don't have to worry about turning it on! Problem solved I do roll down the driver's window depending on how hot it is outside, though. For the most part, I keep it as high as possible.
~ If you don't jump with both feet, you don't move at all ~
2000 Civic DX :: 52/50 psi :: Free Warmer Air Intake :: Duct Tape Aero
"Spare the duct tape, spoil the job."
How to use your A/C more efficiently gascort Hypermiling / EcoDriver's Ed 21 02-18-2010 10:21 PM
Keep A/C from running when you don't need it. TeamCF EcoModding Central 13 04-06-2009 12:55 PM
A/C cycling idea Tony Raine EcoModding Central 5 08-26-2008 03:59 PM
A/C Recirc trikkonceptz EcoModding Central 5 07-31-2008 09:49 AM
Better fuel economy with windows cracked, or A/C? dann_04 General Efficiency Discussion 3 07-30-2008 11:26 PM
