Old 08-26-2009, 10:16 AM   #1 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Calibration of 2010 Prius MPG indicator
With 109 samples, manually collected from the PriusChat community, we now have enough data:
The blue 'dashed' line is the desired, calibrated values. If the indicated mileage were accurate, the data points would bound either side of the dashed blue line. As for the upper, outliers, they are still sparse but they seem to be around the trendline. This is not enough to 'bet the farm' but enough to not worry too much if extended.
The other interesting aspect is the double-humped, MPG distribution:
This closely agrees with the double-humped distribution from the small number of user mileage reports from the EPA database:
At this point, the ball is in Toyota's court. Absent some way to modify the software that calculates the indicated MPG, we just need to understand the problem and depending upon the requirements, there are these options:
  • use pump MPG for accuracy and indicated for relative MPG performance
  • use correction formula: actual = (.85 * indicated) + 5.3
  • use 3d party MPG indicator: scangauge, supermid or others (mpguino)
Feel free to share this with other Prius groups and thank the PriusChat community for their data contributions.
Bob Wilson
Local record
Last edited by bwilson4web; 08-26-2009 at 10:40 AM.. Reason: Correcting alternate MPG device lists.
Old 08-26-2009, 10:23 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
FYI, Yoshi built the supermid specifically for the prius, and he and the folks testing it had the fuel consumption dialed in to within 1%, he also made some key contributions to the mpguino.
Old 08-26-2009, 10:40 AM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Hopefully Toyota will listen and correct this issue. I'd be horribly disappointed if my MFD was as far off as it is.
Old 08-26-2009, 10:49 AM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...does the Prius Owners Manual 'fine print' read: "...your milage may vary"?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 08-26-2009, 01:53 PM   #5 (permalink)
Engineering first
The NHW11/NHW20 had the bladder tank so no one could really check the MPG display without special instruments. If you had special instruments, you didn't really care because you'd use the more accurate source. Regardless, we're letting Toyota know about the problem. In fact, I'll open a case too, now that we know the characteristics of the problem.
One good thing is with the extensive software controlled systems, I suspect Toyota can easily fix this with a download. Considering we've only had our 2010 Prius for 90 days, I think this is remarkable progress.
Bob Wilson
Local record
Old 08-27-2009, 05:05 PM   #6 (permalink)
It looks like what may have happened is that the indicator was calibrated for ethanol-free gasoline (which has more energy per unit volume than ethanol gasoline). Hence the few points that were on or above the indicated line.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 08-27-2009, 07:53 PM   #7 (permalink)
Engineering first
That is an interesting hypothesis.
Ken@Japan reports a Japanese engineer told him they designed it to read 5% high. I suspect Toyota may rethink that approach someday. Regardless the formula derived from the statistical data seems to be more accurate than a straight 5% bias.
Bob Wilson
Local record
Old 05-06-2010, 04:51 PM   #8 (permalink)
After the first 4 tanks on my Prius I am finding that it registers almost exactly 5% high on every tank so far. One on 10% ethanol (10% worse gas mileage) and the other 3 on real gas. I had a J.C. Penny fuel mileage indicator in 1975 that allowed me to calibrate it by putting in actual gallons at the pump. Surprised that Toyota hasn't been able to replicate a 35 year old technology?
Old 05-06-2010, 09:38 PM   #9 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
E10 doesn't have a 10% drop in mileage. E85 might have a 10% drop in mileage; but not E10.
I agree, though about calibrating the stock FE indicator -- the ScanGuage II does it, and so could the factory unit.
Old 05-07-2010, 01:13 AM   #10 (permalink)
Mine do Every time. Three cars, all do the same. Many tanks... Same result.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
Gen III 2010 Prius Matt Herring Hybrids 3 08-30-2010 04:04 AM
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 01:35 PM
2010 - Hybrid System Indicator fun bwilson4web Hybrids 2 08-03-2009 04:47 PM
2010 Prius unveiled: Cd 0.25, 50 mpg EPA combined, EV mode MetroMPG Hybrids 56 07-26-2009 04:48 PM
