Old 04-24-2008, 01:29 PM   #11 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
I get the 9999 from time to time in my CX (D16Y7) I think it's just a software issue.
I was also under the impression that the HX was a 50 state model, while the VX had a 49 and CA variant.
However, Car-part.com shows no selection for CA/49 models. So it is possible one could exist for the HX (D16Y5).
Old 04-24-2008, 02:58 PM   #12 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I have the same engine (D16Y7). When you see 9999, you're in fuel-cut mode. If you let up on the pedal while still in gear, it's turning off the injectors and not wasting the fuel. That's all that's going on there.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 04-24-2008, 03:18 PM   #13 (permalink)
I REFUSE!
thebrad's Avatar
If that's the case would it be better to stay in gear on our generation Civics rather than go to neutral or EOC?
Old 04-24-2008, 03:24 PM   #14 (permalink)
You have to balance it out against the shortened coasting distance. If you're coming in to a stop anyway, go ahead and ride the fuel-cut. Neutral coasting will go farther, obviously, but still use fuel. Mine idles about .3 gph, so at 30 mph, you're at 100 mpg. Not bad. I primarily use EOC, though. I'll use neutral-coasting for a few seconds when traffic demands it, and rarely use fuel-cut. That means I misjudged my pulse rate 1/2 mile back.
Old 04-25-2008, 04:10 PM   #15 (permalink)
About the original question, there's someone on Gassavers who did an ecu swap only and says it's working great for him.
Civic HX owner, seeking 60 MPG WTFM8 Introductions 14 03-10-2012 01:05 PM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
Any guesses on '83 Civic mpg? Ryland General Efficiency Discussion 7 07-12-2008 09:40 PM
part time paper route driver 88 civic. blindsidecustoms Introductions 5 06-14-2008 03:20 AM
WTB: Honda Civic HX Wheels XFi For Sale 2 01-26-2008 07:02 PM
