Old 08-31-2010, 10:35 AM   #1 (permalink)
Wiki Writer
bugler - '91 626
90 day: 35.89 mpg (US)
Call out for test data and mod instructions for wiki
Hi All,
A few of us are getting very useful info into the wiki but we are lacking a lot of “how to” instructions and efficiency test results from many mods (I haven't done all the mods yet). I have had a search through many of the threads and put data into the wiki based on some of that info however a lot of good info is hard to find in the many threads and its very time consuming trying to find the info.
So to all the Ecomodders out there, if you have any test data (ABA test or tank fill up result that isolates a single modification) then please either PM me or post on this thread and ill be happy to put any relevant data into the wiki. If you have already posted your info in one of the threads or if you have seen some really good info in a thread that isn’t on the wiki post a link to the thread and ill get it into the wiki. Of course your all welcome to modify the wiki's yourselves .
For a list of mods we need more information on have a look at the wiki, which is located here, the table summarizes what info we still need.
Car Modifications Main - EcoModder
or here is a list of mods we need efficiency info on.
Lean burn indicator
Vacuum gauge
Mud flaps (deletion)
Raised wing type rear spoilers (deletion)
Shave badges, door handles, rain gutters, etc.
Windshield wiper (deletion)
Aerodynamic front bumper cover Swap/fabricate
Boat-tailing behind tires
Decrease hood to windshield angle
Front wheel arch gap fillers
Frontal area reduction
Pickup truck aeroshell/fastback bed cover
Pickup truck tonneau cover (partial or full)
Rear corner airflow trip feature
Ride height reduction
Sealed panel gaps
Soften / radius aft edge of front wheel arches
Tire spats, or fully contoured deflectors
Upgrade headlights from "bucket" or pop-up style to aero assemblies
Wheel skirts front
Advanced ignition timing
Economy camshaft swap
Engine kill switch for easier Pulse & Glide / Engine off Coasting
Engine swap
Hot / warm air intake
Increased compression ratio
Use lowest viscosity engine oil recommended by OEM
A/C delete
Block Heater
Electric coolant / water pump
Mechanical to electric radiator fan swap
Power steering delete / manual steering rack swap
Regear for lower cruising RPM
Swap from automatic to manual transmission
Synthetic axle/wheel bearing lube
Use thinnest transmission / differential oil recommended by OEM
Solar 12v assist
Lightweight wheels
Replace tires with low rolling resistance tires
Replace tires with skinniest tires recommended by OEM
Aftermarket cruise control
Cruise control mod: fuel economy logic
Hybrid conversion
Weight reduction
Aero fairings
Sprocket swap
Automatic transmission manual gear control (Manumatic)
Torque converter lock up control
Windshield wiper cover
