Old 10-02-2008, 12:59 PM   #11 (permalink)
Anyone given any thought to the Asus EEEpc? They're currently in the $400-$500 range (the smaller one is less, obviously) but will probably be dropping like all other computer stuff. The AC adaptor for them supplies 12V, so you may be able to hard-wire it more easily than one that requires 15V... Plus it's a little tiny thing!
-soD
Old 10-02-2008, 02:22 PM   #12 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
some_other_dave -
Ab-so-moot-lee have thought about the Asus, but can't justify the coin. I would like to resurrect one of my old notebooks with a solid state hard drive and go from there.
CarloSW2
American Solar Energy Society
Old 10-02-2008, 04:09 PM   #13 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
a note about things that run on 12volt bricks; they are designed to operate on regulated 12v NOT automotive 12v which fluctuates widley and typically contains alternator noise. Some things work well; others do not
6 speed ALH TDI
Old 10-02-2008, 09:37 PM   #14 (permalink)
Granted, that. I figured you'd have a pretty stout filter on the power supply. I'm not familiar enough with the technology to know if that would be much more compact/cheaper/efficient than a DC/DC voltage step-up gizmo or not. I'm guessing that it would be, but it is just a guess.
-soD
Old 11-20-2008, 01:31 AM   #15 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Aveo5 SV
90 day: 30.55 mpg (US)
i have a carputer in my aveo. its a great thing to have. ultimate computer nerdness
my 98 Blazer. traded it for the horribly geared Aveo5.
http://www.mp3car.com/vbulletin/show...-b-eby701.html
system transplanted into the Aveo when i traded the Blazer.
http://www.mp3car.com/vbulletin/show...ml#post1247808
that lilliput is a budget screen. never never never use the auto adjust button. you will burn out the resolution its set it. or maybe its the 800x600. thats what mine was set at and i lost it.
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 11-20-2008, 01:40 AM   #16 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
as far as having another monitor, most laptops have a secondary output... remove the primary monitor, after setting the computer up to display to an external monitor, then connect a VGABox (google: VGA BOX) to the computer, and you can use a standard RCA jack after that, which means that any in-car DVD player will accept the signal. It's basically converting the signal from computer-ese to NTSC (or PAL) that will be the hardest part.
BTW, if you only want in-car MP3, you can do it w/o a head unit.. you just need an amp and a equalizer...
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 11-20-2008, 01:42 AM   #17 (permalink)
i suggest looking at MP3Car.com - Powered by vBulletin for any questions you may have. best place to get every bit of info you need. like this forum.
Old 11-20-2008, 03:08 PM   #18 (permalink)
Taurus - '99 Taurus SE
90 day: 17.89 mpg (US)
Windstar1 - '97 Windstar Cargo
90 day: 16.99 mpg (US)
Vulcan - '97 Vulcan 750
90 day: 45.96 mpg (US)
Suzuki - '09 SX4 Technology AWD
90 day: 24.62 mpg (US)
check out mini-itx.com - news
Old 11-20-2008, 06:49 PM   #19 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
Dang, thanks guys! A lot of info and really love the install on the Blazer (great stuff is great stuff)
Old 11-20-2008, 07:38 PM   #20 (permalink)
thanks
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 06:31 PM
Ford Aveo computer change Rpm shift? wally DIY / How-to 5 07-27-2008 01:16 AM
What we are doing at home : electricity (light, computer...) and water groar Saving@Home 8 07-09-2008 04:32 AM
eBay: Zemco FE computer for carb'd cars (not mine) AndrewJ For Sale 1 06-18-2008 01:47 PM
Metro computer swap? daedalusdd DIY / How-to 4 02-18-2008 07:45 PM
